+40 offset
Old Jun 15, 2010 | 10:01 PM
Happy__Fit's Avatar
+40 offset
does my car going to have any problems like rubbing issues if i will install a rim and tire spec of
205/45/16 +40 offset ?
the car is 1.5" drop by H&R springs
Old Jun 15, 2010 | 10:50 PM
Hootie's Avatar
You are going to rub, the offset is low enough for you to catch the rear bumper's tab and possibly the screw attaching the bumper to the body. If you have a GD (see my sig) then it is recommended that you run a +45 offset to avoid rubbing when lowered.
If you check out the several threads in this "Fit Shoes" sub-forum you will find other combinations that work.
Old Jun 15, 2010 | 11:14 PM
MNfit's Avatar
I ran +42 offset on my 16's and only had light rubbing up front from big bumps. I had the same tire size, 205/45/16. My 15's offset is +32 front and +27 rear. The fronts rub about the same as before and the rears are only just rubbing the inner fender lip on medium to hard bumps.
Old Jun 15, 2010 | 11:16 PM
Hootie's Avatar
Were you lowered or at stock height with those 16s?
Old Jun 15, 2010 | 11:45 PM
Happy__Fit's Avatar
im planning to change my wheels to RE-30 with +40 offset.. that is why im asking hehehehe.. guess im gonna have to stick to what i have now.. thanks for the info..
pls close this thread.. case solved.
Old Jun 16, 2010 | 01:07 AM
MNfit's Avatar
I was lowered on skunk2 coilovers
Old Jun 16, 2010 | 01:19 AM
Fitting's Avatar
If you roll/pull/cut the rear bumper mounting tab off then use zip tie then you can run your wheels.
08_vbp_fit
Dec 16, 2016 01:56 PM
sabawballs
Aug 17, 2012 04:11 AM
taFITta_sport
Aug 8, 2010 01:20 AM
Sugarphreak
May 27, 2008 10:50 AM
Frenchi169
Mar 31, 2008 10:49 PM
