History Problems of the Fit
Old Jun 18, 2010 | 08:08 PM
RandomKoko's Avatar
List the problems you had in your fit.
The mileage when the problem occured.
Also to add what year is your fit.
I know depends on how you treat your car, this will able us to alert any problems in the future.
For example:
2008 Fit
25,000 miles
Brakes clunk from pressing the brakes at a slow speed.
Old Jun 19, 2010 | 09:19 AM
wrussi's Avatar
hmm lets see:
2008 fit
30k
recall for the drivers switch
amm thats about it really i havent had any problems with mine.. very reliable car so far! well it is slow! thats a problem for me but i dont think honda can fix that hehe.
Old Jun 19, 2010 | 11:15 AM
Type 100's Avatar
2005 GD1 Jazz, owned second-hand.
~20,000 km: Driver's lock knob snapped in half. Most probably due to the previous owner's mishandling. It's made of ABS plastic, so I know from my experience with plastic models that it's actually rather tough, but it's also brittle and doesn't take too kindly to bending.
~30,000 km: Dealer insists my brake pads are due for replacement, which he does. I measure their material depth at home, and according to the Electronic Service Manual they've still got a lot of life left at 40% depth.
~60,000 km: The front bumper's rubber chin spoiler has worked loose at the middle due to wind resistance on a sustained run at 150 km/h (92 mph). I end up taking it off, because it's doing nothing but plough up loose stones from the road. (Probably not an issue with US GD Fits, but for the rest of the world, check the stability of your rubber chins.)
~62,000 km: The magnetic clutch on the A/C compressor isn't mating well with its flywheel any longer. This causes erratic, fluctuating idle and loss of cabin cooling. Stock rubber spacers on the compressor's clutch and shaft are removed as a temporary fix for better engagement, but if this happens again I'll be looking at a new compressor.
Other than the A/C compressor issue, no real mechanical problems.
Old Jun 19, 2010 | 11:16 AM
wdb's Avatar
wdb
2008 5MT
60K miles
- Drivers door window switch recall at 50-ish K (which I haven't gotten done yet)
- Fun-to-drive meter broke at 5K, probably from being pegged all the time
It's been a rock. Hope it continues!
Old Jun 19, 2010 | 12:37 PM
Flyin172s's Avatar
2008 5spd
Driver-side ABS sensor broke due to my friend letting the sensor wire hold the weight of the brake drum after he let the axle fall out of place when installing my springs. Delaer fixed it under warranty.
Center-Driver-side air vent broke after I hit it... let's say accidentally. Fixed by the dealer under warranty.
Stock tires had to be replaced at something like 20,000 miles due to not getting an alignment after installing my lowering springs.
I think that's it for me. Not sure the mileage the first two occured but since they were both do to owner negligence I don't think it really matters.
One thing worth pointing out, I'm about 37,000 miles and the brakes are just starting to feel worn.
Old Jun 19, 2010 | 01:14 PM
Hootie's Avatar
2008 Sport A/T
No mechanical troubles, just little annoying sequel happens when the rear driver side door's locked with the key fob within a month of getting it. Other than that, no problems at all.
Old Jun 19, 2010 | 01:26 PM
super_fit's Avatar
2008 fit 5mt
35k
Catalytic Converter Crapped out
Old Jun 19, 2010 | 02:20 PM
Santiad's Avatar
2009 ge8
2009 GE8
42,000 miles
tires, brakes, replaced
defective trunk lock switch
Old Jun 19, 2010 | 06:25 PM
grtpumpkin's Avatar
2008 Sport manual trans 70,843 trouble free miles. Unless you count the dashboard rattles (caused by me) the persistent CEL (code 0507 caused by me) and the missing drivers rear door c-pillar cover (caused by, you guessed it, me)
Old Jun 19, 2010 | 08:24 PM
RandomKoko's Avatar
sounds like we don't have a lot of problems with our fit. did any of you guys experience any clutch noise when pressing or releasing the pedal?
Old Jun 19, 2010 | 11:14 PM
Type 100's Avatar
That seems normal. The clutch has its own whine when it's engaged - when you release it the engine idles slightly quieter. Not really a concern though.
Old Jun 20, 2010 | 10:36 AM
Rob22315's Avatar
2008 Base AT Fit 25K miles
Driver's side speaker blew. Paid Honda $50 for a new paper speaker. What a ripoff. Replaced it myself.
Getting ready to do the window switch recall.
Otherwise, love the Fit. Best bang for the automotive $ IMHO.
Old Jun 20, 2010 | 12:00 PM
Snoodmaster's Avatar
13000 mi
2009 auto sport
Rear hatch struts stopped holding the hatch up. Replaced by dealer under warranty.
Old Jun 20, 2010 | 04:23 PM
einstein77's Avatar
2008 Fit Sport
20k miles, now.
When "new" til today.... light switch will go to high beam even when set in low beam detent.
Recall for door switch.
Old Jun 23, 2010 | 12:12 PM
vze29tgr's Avatar
2010 Fit Base
7400K
Drivers side seat makes a clicking noise when going around turns, etc when a passenger is in the seat. Sounds like it might be loose. Taking it in July 2nd for that and 1st Oil change/ tire rotation.
Old Jun 23, 2010 | 12:43 PM
Krimson_Cardnal's Avatar
Originally Posted by vze29tgr
2010 Fit Base
7400K
!!WOW!!
So how is it without a passenger in the seat?
That might be the solution....
Old Jun 23, 2010 | 02:10 PM
vze29tgr's Avatar
When its just me, I don't hear anything. Only when there is a passenger, regardless of weight.
Old Jun 23, 2010 | 02:31 PM
einstein77's Avatar
Maybe its the weight sensor that is used to determine if the airbag should be activated (ie, empty seat or not), and if it is of child weight (ie child deployment setting). Maybe it's cycling thru. I don't know if this is a mechanical switch that you can hear, or not.
Old Jun 23, 2010 | 02:32 PM
i think my front bearing (driver side) is shot. been howling the last couple of months, hasn't worsened so havent taken it in yet....too busy and lazy at the same time.
Old Jun 27, 2010 | 12:05 PM
ftlmatt's Avatar
2008 Honda Fit Sport A/T w/paddle shifters..
recall for window switch...needed a cover plate to prevent excessive water from entering it. was replaced next day.
the gaps between my doors aren't as tight as they use to be...anyway i can fix this?
