Offset
Old Jun 30, 2010 | 11:03 AM
taFITta_sport's Avatar
Offset
Getting some rims 17x7 offset +52. Want to get spacers either 20mm. Would it rub? Oh yeah fit dropped 1.6in. Tires will be 205/40
Old Jun 30, 2010 | 11:08 AM
MNfit's Avatar
with the spacer your offset will be +32 so, yea you probable will rub
Old Jun 30, 2010 | 11:10 AM
gd3vbp's Avatar
This, that is a huge spacer too. If you're going 20mm you'll need extended studs.
Old Jun 30, 2010 | 11:17 AM
Extended studs man that sucks. Y does spoon have to make such a sucky offset.
Old Jun 30, 2010 | 11:32 AM
BlueCell's Avatar
You'll rub. I'm on a +32 offset. You'll need a major fender roll with a pull. 20mm spacer (adapter type) wont need extended studs. I suggest buying a 15mm spacer. It will save you some trouble and it will still rub, just not as hardcore.
Old Jun 30, 2010 | 12:04 PM
So no need for extended studs n will rub great!
Old Jun 30, 2010 | 12:11 PM
BlueCell's Avatar
Old Jun 30, 2010 | 12:18 PM
ghg78's Avatar
what spoon wheels are you talking about?
Old Jun 30, 2010 | 12:27 PM
Cr93 coming the end of July
Old Jun 30, 2010 | 12:31 PM
Thinking about getting project kics from evasive motorsports looks about the same
Old Jun 30, 2010 | 12:47 PM
ghg78's Avatar
I didn't know they were making a 4x100 one.
Old Jun 30, 2010 | 12:55 PM
Yeah I ordered the silver ones n it's coming at the end of July. Thinking about powdercoating it a different color though. haven't decided which color yet, but definately going to need wheel spacers.
Old Jun 30, 2010 | 12:59 PM
MNfit's Avatar
I would suggest a 10mm. You shouldn't need new studs and +42 should bring the wheel very close to the fender with little to no rubbing.
I have been thinking of getting those spoons as wheel, jsut really wish they made a 16"
Old Jun 30, 2010 | 01:15 PM
BlueCell's Avatar
Yep, there was a thread about this in the ajr forums
https://www.fitfreak.net/forums/aj-r...93-wheels.html
10 mm is for minimal work to your fenders or none at all. But yea, I'd still get a 15 for the more flush look.
Old Jun 30, 2010 | 01:40 PM
Yeah decided to go with the 15mm spacers just can't wait to get them. Thanks blue and mn for all the inputs.
Old Jun 30, 2010 | 01:46 PM
ghg78's Avatar
Nice.i really like the blue
Old Jun 30, 2010 | 02:22 PM
Don't really mind the blue, but I'm going to change the color of the rims n e ways to either matte bronze or gun metal maybe even try to get that blackish blue that are on the weds sa70's
Old Jun 30, 2010 | 07:02 PM
mahout's Avatar
get 6 mm 9i/4"0 spacers so your offset then will be 46 mm. Probably OK with your 1.6" drop.
(weve found that many dropos don't match the advertised ones so measure yours: fender cnter point before and after drop on all 4 wheels.)
And the 205/40x17 tire is same diameter as stock pre09 but is heavier. Actually 195/40x17's will work better for mpg and acceleration; no penalty cornering by comparison. And no rubbing as we have one here so equipped on 45 mm offset. cheers.
Old Jun 30, 2010 | 07:14 PM
Well i have a set of 17x7+45 and it doesnt rub with my drop, but i want the offset to be a little more flush so it will look a little more aggressive. I didnt know about the 195 tires doing that so i might get a 195 tire setting.
Old Jun 30, 2010 | 10:44 PM
Is there a place that n e one knows besides evasive that i can go and buy the 15mm wheel spacers?
