L13a turbokit?
Old Jul 5, 2010 | 07:41 AM
Machiel's Avatar
L13a turbokit?
I need some more power So i'm willing to buy a turbokit for my Jazz GD1 (european )
And that's why i have some questions..
-What are the differences between a turbokit for the L15a and the L13a1?
-Is there a turbokit specially for the L13a1?
-What do i need extra, when i order a L15a turbo kit? do i need to do some extra modifications? or is it plug and play?
- Do i need another ecu? conversion harness? easy to tune? (obd?)
Many thanks
Old Jul 5, 2010 | 07:34 PM
Type 100's Avatar
I know a few people who make a turbo kit for the GD Jazz/Fit that will fit either the L13A or L15A.
SPEEDLAB | The Science of Speed
The contents of the kit are listed on that webpage. For tuning, Speedlab uses a Dastek Unichip piggyback fuel controller to adjust air/fuel ratios - the tuning is the important bit really.
They made a variant of this kit that doesn't use a 5th injector - instead, it swapped the stock injectors for larger ones from a CR-V, if I'm not mistaken. An acquaintance of mine had it installed and he said that larger-injector variant has greater scope for tuning.
You could duplicate the parts pretty easily but you're on your own for the tuning and turbo-specific intake manifold.
HTHs
Old Jul 6, 2010 | 08:46 AM
Machiel's Avatar
Thanks
Why should i need a 5th injector with other kits? Can't i just buy me some bigger injectors?
I've seen some kits on ebay, but don't waht i should think of those kits
Kraftwerks has a kit for a usdm fit ( L15) but think it is too expensive... I'm searching for a 2000$-3000$ kit... Is this available somewhere?
Old Jul 7, 2010 | 02:04 AM
Type 100's Avatar
Originally Posted by Machiel
Thanks
It's for the fuelling. Either way looks acceptable. As long as you're feeding the engine enough petrol, it shouldn't matter whether you run a fifth injector or get bigger ones than stock.
Old Jul 7, 2010 | 06:21 AM
Machiel's Avatar
That's what i thought... I was when i heard that there was a 5th injector needed
Old Jul 7, 2010 | 09:32 AM
Type 100's Avatar
Hahaha! It's not unique to the Fit mind you, I know there are MX-5/Miata owners who've run a fifth injector in their turbo setups as well. If it works for them, it should be viable for our cars too.
vertex.mn
Apr 15, 2012 06:54 AM
splodge
Aug 10, 2011 05:27 PM
SWRWKFS
33
Mar 31, 2010 08:07 PM
Starfox3
Aug 14, 2008 06:32 PM
ride_the_pony69
Sep 9, 2007 10:28 PM
