Pulling Front Fenders
Old Jul 29, 2010 | 01:55 AM
chinkyy's Avatar
approximately how much space would be created?
Old Jul 30, 2010 | 03:06 AM
chinkyy's Avatar
someone answer!!! pleas
Old Jul 30, 2010 | 12:07 PM
Mr08FiT's Avatar
How about a more specific question... From what I've heard most people pull the fender to fit to a specific wheel/tire combo they have already selected.
Old Jul 30, 2010 | 03:43 PM
L-Bear's Avatar
depends on how much you pull and what size wheel and offset your trying to fit.
Old Jul 30, 2010 | 06:39 PM
Fit4Trav's Avatar
Yeah,
I really depends on how MUCH you pull and roll. Make sure the fender is heated up so they are pliable and you dont chip paint. I would recommend putting the wheels you are trying to fit on and then measure (or eyeball)
Old Jul 30, 2010 | 07:26 PM
chinkyy's Avatar
i know the wheels will stick out a little less than an inch. i was just wondering if the fender can be pulled that wide
Old Jul 30, 2010 | 07:36 PM
Fit4Trav's Avatar
Im sure they can the fenders are soft. I would recommend having a body shop to it though for that much of a roll and pull
Old Jul 30, 2010 | 08:33 PM
gd3vbp's Avatar
My fronts were pretty flush, I was able to roll and pull by hand, had to do it gently. I'm not sure I could have gone any further without heat and a roller or bat.
Old Jul 30, 2010 | 09:57 PM
Fitting's Avatar
You can pull an inch(25mm)with no problem. I and a bunch of people done it already.
Old Jul 31, 2010 | 03:59 AM
danger69's Avatar
Any pics of pulled fenders front and rear. Sounds like the next best thing when having low offset wheels. Plus I think it makes the fit looks a bit more aggressive.
Old Jul 31, 2010 | 08:10 AM
crash001's Avatar
how did you pull it by hand just grabed and pulled?
Old Jul 31, 2010 | 11:00 AM
gd3vbp's Avatar
In essence yes, but if you go at it like a fucktard its going to show because it'll be wavy. Pull back the front fender liner and tuck it under the lip on the fender and you should slowly be able to bend that flat, then you can pull it evenly.
Old Jul 31, 2010 | 02:09 PM
Fit4Trav's Avatar
Or let the wheels do the rolling as it rubs up front Kinda what i did
Old Jul 31, 2010 | 02:18 PM
L-Bear's Avatar
i used a heat gun and a phone book..... hah
Old Jul 31, 2010 | 02:48 PM
Mr08FiT's Avatar
+1 on the heat gun if you're not going to fork out the $
I used a heat gun and rented a roller from a local shop and I still have nasty chips in the rear.
Old Jul 31, 2010 | 02:58 PM
L-Bear's Avatar
I didn't get any chips at all. well in the rear I did but not from rolling, it was from hammering hah
Old Jul 31, 2010 | 03:09 PM
Mr08FiT's Avatar
+1(agreeeeed)
lowkeymods
Aug 17, 2012 01:31 PM
skinny
Aug 7, 2011 11:52 PM
Amageus
Mar 6, 2009 05:44 PM
Kane1313
Jan 21, 2007 01:20 AM
Halo
26
May 22, 2006 10:39 PM
