Valentine One Hardwire... Where? How?
Old Aug 25, 2010 | 03:51 AM
wootang00's Avatar
Hi Guys,
I'm a complete noob when it comes to hardwiring but after 2 tickets in 1 month I think the time has come where I need to splash some money into a radar detector.
That said I dont want to use the cigarette lighter to power it up and want to hardwire it.
Ideally I would like to hardwire it but also be able to "snap" it off when I need to take it off the car easily to move it to another one. And of course quickly "snap" it back in when I bring it back.
Any ideas on how to get this accomplished?
Know anyone in the LA/OC area that maybe able to do this for relatively cheap?
Thanks again!
Old Aug 25, 2010 | 08:16 AM
Punisher11's Avatar
hmmm... when you say hard wire, its usually permanent. unless you have 2 sets of the power supply cord.
check out specboy's car domain page on his sig on this thread
https://www.fitfreak.net/forums/2nd-generation-ge-08-present/58391-new-fit-owner.html
Old Aug 25, 2010 | 09:25 AM
specboy's Avatar
Thx Punisher.
Woo, Nice choice of Radar. Mine is 11 yrs old and still going strong - still on the original suction cups too. - Been hardwired in 3 vehicles (2 integras and the FIT) and gets moved to the Ridge with the Cig adapter for long trips.
As for the install... it is EASY! - if you can work pliers, you can do this.
what you'll need is:
  • an "Add-A-Fuse" from your local autoparts store.
  • Extra Fuses - (Add-a-Fuse doesn't come with any)
  • A 9' 4-wire phone cable (6' works but is tight - no slack)
  • A 6' 4-wire phone cable (if you are mounting the concealed display as well)
  • Either A Soldering Iron and heatshrink tubing (or some buttsplices and crimpers)
  • About 1 hour of your life that a significant other can do without.
also, with the Add-A-Fuse, this is completely removable (takes about 2 min to completely remove - including phone wire) with no cutting or splicing into the factory wiring anywhere in the car. If I ever have to remove the V1, I'll leave the $2 phone cord behind the dash/tuck it into the roof liner and not worry about removing it. it's $2...
I actually have photos for a DIY, just never threw it together. I'll see if I can do it tonight or tomorrow. Don't have the Concealed display mounted or hardwired yet so I can only do the Radar portion now. Will add the CD at a later time.
~SB
Old Aug 25, 2010 | 12:57 PM
wootang00's Avatar
If you could that would be great.
First time I am doing this so I kinda know what im doing or breaking.. Haha.
Thanks.
Old Aug 25, 2010 | 09:57 PM
caliban10010's Avatar
Check the link in my sig. Hope it helps. I also included an on/off switch in my install.
Old Aug 26, 2010 | 03:51 AM
wootang00's Avatar
looked at your write up.
if you tap your map lights wont the detector always be on?
Ideally I would like it so that only when the ignition is on the detector will turn on...
Old Aug 26, 2010 | 11:59 AM
Shora's Avatar
Please, do post a DIY on this.
I had the V1 with concealed display hard wired into my Marauder. I don't want to tap into the ignition wires on my Fit(s) so it's been sitting in a box.
Hook us up.
Originally Posted by specboy
Thx Punisher.
~SB
Old Aug 28, 2010 | 02:20 AM
I installed a custom switch which is linked in the 1st post and in my sig.
Old Aug 28, 2010 | 08:43 PM
feddup's Avatar
type?
Are the fit's fuses ATO or mini? I believe they're minis but want to be sure. I'm about to hardwire a 9500ix RD.
Old Aug 29, 2010 | 10:24 AM
specboy's Avatar
They are the mini but the "low profile" mini so they don't have the two spades that stick out of them. The Mini Add-A-Fuse works as I have one on mine but you can't use the stock fuse in the add-a-fuse, you have to use two standard mini fuses.
I can't find my photos from the V1 install which is a bummer but I'll see if I can take a photo or two of the fuse box. I used the 12V accessory (Cig lighter) and put a 20a fuse & 5a fuse in the add-a fuse. The 20 to replace the stock 20a that was in there, and a 5v for the V1 Hardwire. (the v1 has a 1a or 2a fuse built inline anyway so now it is double-fused)
~SB
Old Aug 29, 2010 | 11:34 AM
feddup's Avatar
Thanks
~SB
Thanks greatly for the info! I already ordered the add-a-fuse mini version from Amazon along with the hardwire kit so I should be OK. I wondered if I could use another add-a-fuse to create an under dash cig lighter for my GPS? I don't see why not! That would free up my cig lighter in the console and make things neater. Thanks again for the information.
Old Aug 29, 2010 | 12:36 PM
specboy's Avatar
Yes, you can use an add-a fuse for that. I'm going to get one of them for the Ridgeline to Hardwire the Harman Kardon Drive+Play that controls my wife's iPod. I may also add a USB Power Port to the fit for my phone/misc USB Powered devices like my Archos or iPod.
For those who are interested, I did a How-To on the V1 hardwire install and slapped it both here and on my Cardomain Page. Page2
https://www.fitfreak.net/forums/2nd-...tml#post903938
http://www.cardomain.com/ride/3368795/2
hope it helps everyone.
~SB
Shravan S. Dwarka
Mar 19, 2017 07:25 PM
CBX
Nov 26, 2015 02:24 PM
polokid69
May 10, 2010 12:50 PM
Ritzbury
Nov 24, 2007 12:47 PM
sillypuddy
Nov 23, 2006 03:34 PM
