Vacuum Gauge in a GD Jazz
Old Sep 21, 2010 | 02:24 AM
ENTHNS's Avatar
Installed one today and I'm wondering if it only reads up to 5-7in. of Hg (mercury)? What's the normal vacuum reading? Where do I tap for the vacuum hose? I tried the brake master cylinder vacuum hose and got the same reading. Is this due to the small engine of the Jazz? My other rig is a Nissan Patrol with a 3 liter donk. Thank you.
Old Sep 21, 2010 | 01:24 PM
Happy__Fit's Avatar
IMHO
i think you should have bought other brands that has independent sensors...
here's my share.... vacuum/water temp/volt meter
IMG_0068.jpg?t=1285089810
25 in HG is my idle vacuum without AC on
19-20 with AC on.
HTH
Old Sep 21, 2010 | 04:54 PM
Scala's Avatar
oh man those gauges look nice @Happy__Fit, where did you get them and how hard were they to install?
Old Sep 21, 2010 | 10:26 PM
ENTHNS's Avatar
Where did you tap for the vacuum gauge sensor? What's an independent sensor? The vacuum gauges I have used always have a dedicated air line that you tap onto a vacuum line.
Old Sep 22, 2010 | 06:26 AM
dewthedew's Avatar
tap it just before the intake manifold vac line.
Old Sep 22, 2010 | 07:57 AM
ENTHNS's Avatar
Total newbie here. Which particular hose would that be on the 1.5? Thanks!
Old Sep 22, 2010 | 08:19 AM
apexanimal's Avatar
if it's an electric gauge (has map sensor included) it will sit wherever you last were when you shut it off, then when you turn the car on it will recalibrate itself to "0"...
if it's a mechanical vac gauge then where it sits when the car is off is "0"... i think this is what you have? if so, either add 5 to whatever you're seeing, or get a new gauge...
Old Sep 22, 2010 | 08:45 AM
ENTHNS's Avatar
It's mechanical, with an airline you have to tap onto a vacuum line. When the engine engine is off, the gauge points to zero.
I'm just wondering which hose I should tap into.
Old Sep 22, 2010 | 11:08 AM
NIGHTHAWKSI's Avatar
open your hood, look at the intake manifold.
front center (between teh manifold and the radiator) you will see a small diameter hose that connects to a nipple on the intake manifold. tap into that hose.
Old Sep 22, 2010 | 11:27 AM
Happy__Fit's Avatar
i dont know the brand/model of these gauges...
my brother bought this from hong kong and gave it to me
thanks for appreciating
Old Sep 22, 2010 | 12:09 PM
AttoirRE's Avatar
Why?
Why did you guys install a vac gauge in your car?
Old Sep 22, 2010 | 06:27 PM
ENTHNS's Avatar
Is that hose visible in my second photo on the first post? Thanks!
Old Sep 22, 2010 | 07:56 PM
polaski's Avatar
Old school way to drive for better mileage. Easier to keep in closed-loop, easier to keep consistent manifold pressure under acceleration, et cetera.
One day my old Stewart Warner vac gauge will find its way back into my car.
Old Sep 24, 2010 | 06:11 AM
ching1206's Avatar
i also have waater temp,vacuum, n volt meter...
but then my vac is broken..lol dont work
Old Sep 26, 2010 | 05:38 AM
ENTHNS's Avatar
Anybody figured out yet which hose I should hack into?
Old Sep 26, 2010 | 09:54 AM
polaski's Avatar
As long as it's not the PCV line and not the brake booster line, I don't think it matters.
eyepon
Asia Fit Forums & Clubs
Nov 30, 2014 06:38 AM
banane
Jul 15, 2013 06:39 AM
KL-Jazzer
Nov 24, 2009 11:15 PM
F0NIX
Jan 28, 2009 10:26 PM
thaijim
Feb 29, 2008 02:46 PM
