Wierd water noise in engine on startup
Old Sep 28, 2010 | 09:52 PM
mdsniper7's Avatar
Question Wierd water noise in engine on startup
so I have a 08 fit with 40k and when I start it up I hear what sounds like water swishing in the engine, but no cel everything runs fine, wtf is that noise sounds like a water park in my engine lol.
Old Sep 28, 2010 | 10:06 PM
Krimson_Cardnal's Avatar
did ya check coolant levels?
Old Sep 28, 2010 | 10:55 PM
vinnymac's Avatar
Burping you radiator
Jus' had the same type of problem....don't fret. One of our wonderful readers (can't find his reply) suggested that I jack-up the front end of my car (tires are off the ground) while the engine (running) is still {cold} remove the radiator cap, turn heater on high and the air bubbles with rise to the top and dissapate...yeah I know that sounds strange, however; I did it and the problem has been gone ever since. You will have to have extra coolant to refill to normal level after the air is all out. Hope it helps!
Old Sep 29, 2010 | 01:02 AM
mdsniper7's Avatar
What's weird is when u Google it it says means a blown head gasket that can't be 40k miles no way
Old Sep 29, 2010 | 02:08 AM
vinnymac's Avatar
Well, mine has about the same mileage as yours and the jac'd-up thingie worked jus fine for my car
I hope like h@%$ that your head gasket is not blown.... I would think that their would be other problems associated with the blown gasket within your car....but u say it's still running fine.
Old Sep 29, 2010 | 01:22 PM
mdsniper7's Avatar
had coolant flush its still there so there looking at again
Old Sep 29, 2010 | 02:57 PM
mdsniper7's Avatar
they flushed again and burped it and its gone, thats really wierd I am just wondering what could have caused it and what did it do internally to my engine
Old Sep 29, 2010 | 03:32 PM
burped up a bubble of air. No harm done to your engine. Quite often common in cooling systems.
Old Sep 29, 2010 | 04:14 PM
mdsniper7's Avatar
Ok cool thanx
Old Sep 29, 2010 | 06:46 PM
vinnymac's Avatar
Angry Dayum!
Sad to hear that news....whatever the diagnoses is found out to be please let me-and the community know for future reference.
Since I {had} that same problem I'm beginning to think that jus' maybe I could have incurred some internal engine damages as well.
Old Sep 29, 2010 | 07:39 PM
How so?? A bubble in the cooling system tells me the water pump is pumping at the low end of a curve.
Old Sep 29, 2010 | 09:51 PM
Sherpa's Avatar
Cooling system is sucking air somewhere.. hose.. pump.. radiator.. radiator cap...
Old Sep 30, 2010 | 12:03 AM
mdsniper7's Avatar
its gone now but u think its sucking in air somewhere, that would be rare on a newer car, getting me worred wonder if i should run a dianostic.
Old Sep 30, 2010 | 09:55 AM
Seriously doubt you have a problem, simply keep an eye on the reservoir tank levels. It was air locked, that's all.
Old Oct 21, 2010 | 08:36 AM
5speedwonder's Avatar
same thing happened to me, turns out i had an itty bitty baby pinhole in the coolant line running to the throttle body. replaced the hose, burped the system, problem solved.
Old Oct 21, 2010 | 10:27 AM
+rep to 5speedwonder Good clue to potential coolant issues.
One thing all should keep in mind is that coolant has a distinctive 'sweet' odor.
There should be no smell in the engine compartment or vehicle cabin.
If so, guess what.
Old Oct 21, 2010 | 04:20 PM
yah, nearby my town there's a candy manufacturing plant. each time i drive past there i get that sweet candy smell coming through the vents and im wondering if i have coolant leaking.
Old Oct 21, 2010 | 07:03 PM
DiamondStarMonsters's Avatar
OP, if it was your headgasket your oil and coolant would be mixing and look like chocolate milk, and their would be other major issues. There was probably just air stuck somewhere along the line. If still worried, lay down some newspaper and park your car over it and look for drips.
Originally Posted by armandjones82
If ever, try to change up your water pump like what CVU Brand and the others would want to offer you. I hope that the noise would be fixed if you try to look for other options.
Out of curiousity I followed your link and they do not carry any water pumps for GD or GE Fits.. But you can get a steal on an OE clutch kit made by Daikin (~$175) though I don't really know anything about the company to be honest.
Also for those who are looking for replacement or upgrade water pumps make sure you get a metal "closed" impeller to avoid cavitation and premature pump failure.
Old Oct 23, 2010 | 05:24 PM
markwalter's Avatar
weird because my shits been doing the same thing!
i was wondering what it was, i might try this jack the front end up thing here soon! but till then, do you think its causing damage at all?
Old Oct 23, 2010 | 05:25 PM
markwalter's Avatar
but its only when i first turn my car on like in the morning or when my car has been sitting for a long time. im guessing its when it has cooled off? not all to sure, i hate car problems.
