Were do you have LED's @ in your Fit/Jazz
Old Oct 19, 2010 | 10:23 PM
Perrenoud Fit's Avatar
Lightbulb Were do you have LED's @ in your Fit/Jazz
Old Oct 19, 2010 | 11:29 PM
jazz6768's Avatar
Very Nice!!
Old Oct 23, 2010 | 12:07 AM
Lightbulb Driver's Side
Old Oct 23, 2010 | 11:57 AM
jeff_1986's Avatar
Just in my driver and passenger foot well for me. I like the extra lighting for at night though. They don't appear to be as bright as yours are in your pictures, but they aren't dull either. Don't think I have a pic of them at the moment, but I'm sure you get the idea lol.
Old Oct 23, 2010 | 09:02 PM
Vizibelli's Avatar
I have LEDs at map lights and dome light.
Trunck
Foot well
And parking light. (sorry, no pics).
Will instal leds at license plate.
Old Oct 23, 2010 | 09:15 PM
Man that's a nice application w/ the blue LED's and Leather seats Whoot Whoot!
Old Oct 24, 2010 | 09:07 PM
Vizibelli's Avatar
Thanks. Its was made with a 1 meter (divided in 2) water proof blue led strip (only US$15.00) hooked at the dome light in the fuse box. Wiring was made using instructions of a D.I.Y. found here at Fit Freak.
Your engine bay is awesome. How many and where the leds are located in there?
Old Oct 24, 2010 | 09:50 PM
Thanks!
Maybe 30+? 1- 24 LED strip under the tower brace and 8 or more 5mm blue and orange up front. There's a plastic shield in front of the radiator and I drilled it with 3/16" holes and the 5mm LED's fit snuggly. The strip LED's were hi priced till recently most everything I've done is with the 5mm LED's I just bought 50 blue 5mm shipped for 2.98 off Ebay. If anyone's interested let me know & I will look the seller up & send the info on.
Mike
Old Oct 24, 2010 | 10:05 PM
Old Oct 25, 2010 | 12:13 AM
Type 100's Avatar
Same here. Just the footwells (actually they're CCFL tubes) and one small LED "mat" for my dome light. I got them in white as they're more for functionality than gaudiness.
I might replace the dome light LEDs for something brighter soon as a couple of them have burnt out already.
Old Oct 25, 2010 | 12:29 AM
jazz6768's Avatar
Very very very nice
Old Oct 29, 2010 | 11:02 AM
SoUnFit's Avatar
CCFL Tubes in the driver and passenger side footwell
LED board in the dome light (18 or 24 dont remember)
two 9(?) LED boards wired together for the cargo lamp
LED license plate bulbs
LED parking bulbs
gonna switch out the CCFL for LED strips, rather have the CCFL's in my other car
Old Nov 30, 2010 | 05:15 PM
hkfooey's Avatar
Those are nice under your hood bro!
Old Dec 27, 2010 | 07:09 PM
Check this out .................. ya I know F&F
http://www.youtube.com/watch?v=wBGLo5kBLiQ
Old Feb 5, 2011 | 10:53 PM
theindiearmy's Avatar
Do you guys remember how many volts you are running to each component and/or how many volts max are allowed at each component? I'm looking at doing this all myself but don't want to need an extra power source or get too extensive with it.
For example, I heard that the Dome light is 5v, but is that also the max allowed, or can it be replaced with an LED board that runs 12v, etc. etc.?
Thanks,
Indie
Old Feb 6, 2011 | 09:11 PM
Welcome Indie,
If the LED's you have are 5v max then a resitior will need to be added in a 12v system.
If your buying LED's then check to make sure they are for 12v applications, most are. look them up on E-bay LED 12v. The power use of the LED is much less than the oem bulbs (amp. draw)
Old Feb 6, 2011 | 10:36 PM
Thanks for the reply. I went ahead and got a nice blue led kit for about $10 and put it in. It's not as bright as the white LED, which is expected, but it's brighter than the OEM, plus has a nice blue accent touch. I'm not sure about others, but I heard that some lose the fade effect when switching them out. Mine did not, still a nice blue fade which I'm happy about as well.
Here is an album of before and after.
http://imgur.com/a/9GeKN#tNfaK
Old Feb 9, 2011 | 10:14 PM
cfran55's Avatar
dang i need to replace the lights in the ambient lighting they are weak
Old Feb 10, 2011 | 12:45 AM
hkfooey's Avatar
The original dome lights in our FIT sucks - it is relatively easy to replace: 1 screw driver and 5 minutes max... the foot light (that ties to your fuse box takes a bit longer)...
Old Feb 12, 2011 | 04:18 PM
Klasse Act's Avatar
Thumbs up
Both map lights, dome light, rear cargo light and licence plate lights
