Searched, but no luck. Anybody running 13" wheels on their Fit.
Old Oct 20, 2010 | 05:10 PM
Made in Japan FIT's Avatar
Anybody got any pictures of Fit on 13" wheels? Just curious.
Old Oct 20, 2010 | 08:20 PM
Type 100's Avatar
13" steelies were stock on the lowest-spec GD1s here. No pictures unfortunately, but yes the GD will run them no problem.
Old Oct 20, 2010 | 09:41 PM
Texas Coyote's Avatar
I like the idea of 13" wheels..... There are performance gains to be had by doing so.
Old Oct 20, 2010 | 09:53 PM
Perrenoud Fit's Avatar
That's what I like about you Tex........
While most here are think'n 13" noway! 17, 18, 20 if we could cram 'em up in there.
But less mass and a smaller diameter will wind up quicker! definitely proformace gains to be had there. Like Carrol Shelby use to gauge his cars "0 to 100 and 100 back to 0 how fast can ya get there and back?"
Old Oct 21, 2010 | 10:10 AM
I appreciate the input everybody. I did found a post about 13" wheel under Tire, but someone said 13" won't clear the caliper. I'll have to try it out and see. I want to run 13's wheels because I have a complete new set of 13" Mugen CF48 sitting in my closet. Why not put them to use if I can plus I don't really drive my car anyways just sits in the garage. Thanks guys.
Old Oct 21, 2010 | 10:32 AM
cr4zy3lgato's Avatar
If you run into this problem, just put small spacers and extended wheel studs...
Old Oct 21, 2010 | 10:39 AM
Thanks for the tip Crazy3gato. I didn't think of that. I do hace Skunk2 extended stubs, spacers, Red Volk Formula lug nuts sitting in the storage. I can put them to use too, but I really want a Yakima roof rack before I get into all that stuff.
This site is awesome.
Old Oct 21, 2010 | 07:12 PM
Blue-Civic-Hybrid's Avatar
If you ever get these 13's on, be sure to post up some pics. I'm still debating whether to powdercoat my old Mugen RNR's a new color...
Old Oct 31, 2010 | 04:01 AM
I am sure hoping someone is able to find out if there are 13" wheels that will work... If anyone pulls it off, please post some photos.
Old Oct 31, 2010 | 04:05 AM
jazz6768's Avatar
Old Oct 31, 2010 | 04:55 AM
Fitting's Avatar
In for pics if it happen.
Old Oct 31, 2010 | 07:55 AM
Old Oct 31, 2010 | 12:26 PM
Question Maybe 14's?
How about 14 inch wheels? Plenty of OEM Honda wheels (old CRX Si wheels) and old Miata wheels (Wantanabe's) are on Craigslist and forums.
Bump up an inch and your options open up!
Old Oct 31, 2010 | 01:04 PM
There just aren't as many choices in performance tires or sizes in 14" compared to 13".... I think a 225-45-13 on 13"X8" wheels with Moon Eyes aluminum disk wheel covers would be a killer looking combination on a Fit..... It would resemble some of the old Hot Wheels toy cars and no one has done that type of setup on here yet... Personally I like 175-50-13s on 6" rims with spacers and Moon disk... The wheel diameter would be 19.889" and weight per wheel/tire would be 25lbs.
Old Oct 31, 2010 | 01:11 PM
bmxman's Avatar
hmm...I think the biggest drawback would be the weight. If I can run 15" wheels and tires that weigh just under 28lbs. then 13" wheels should be a lot lighter no? Now if you could get 13" wheels and tires under 23lbs that would be pretty awesome, although you would give up a good deal of ground clearance....as well as a much smaller contact patch.
Old Oct 31, 2010 | 01:41 PM
You would 1.75" with the 175 55 13s and they are 6.8"wide. You would sit right about 3/8" higher with the 225-45-13s that are 8.9" wide and the weight would be around 28lbs but closer to the center of rotation than stock size wheels and tires requiring less power to spin... The reduction in diameter has the same effect as changing the final drive ratio which has the effect of multiplying the torque.. The 225-45s are racing tires not for use on public roads though..... The reduced diameter allows wider tires to be used with a lesser chance of rubbing the fenders also. Check out the tire sizes available in 13" compared to 14", there are a lot more in 13" especially performance oriented tires.
dampcurse
Apr 13, 2019 04:09 PM
Theos92vr4
Mar 16, 2012 06:25 PM
fjt
Dec 10, 2009 08:54 PM
constructicon
May 8, 2008 08:39 AM
puma1824
Apr 2, 2007 08:28 PM
