I know one of you guys has pulled your GE8 headliner
Old Oct 21, 2010 | 10:07 PM
Sherpa's Avatar
I'm going to pop an NMO mount in the roof.. means drilling a 3/4" hole with an NMO hole saw. Anyways, I need to make sure I don't hit any cross beams or wires with the drill and I won't want to pull the head liner.
What I'm wondering is.. if anyone has had their headliner out for whatever reason and can tell me where the dome light wires run and if there's a cross beam under the sheet metal?
The hole saw is designed specifically for this application.. won't go deep enough to damage the head liner but it will cause a problem if it hits any wires mounted directly to the roof where I drill......
Old Oct 22, 2010 | 12:06 AM
circa40's Avatar
Old Oct 22, 2010 | 01:00 AM
Sherpa's Avatar
That is perfect!
Looks like I can reach in and feel the cross braces...
Since you've done the audio stuff, any thoughts on disassembling any of the interior plastic? What about a good clean source for power?
Old Oct 23, 2010 | 02:46 PM
Sherpa's Avatar
Did some exploring today.. going to pop the NMO dead center, right between the brace at the dome light and the one from the rear hand holds.
dukers
Sep 19, 2015 05:43 PM
heymikesays
May 8, 2012 12:41 AM
kirinzon
May 30, 2011 06:19 PM
fskelly
Aug 12, 2010 11:59 AM
tj_boof
Jun 20, 2009 10:02 PM
