A/C troubles, please help me diagnose.
Old Oct 22, 2010 | 07:37 PM
Oofie's Avatar
I've been having A/C troubles for the past couple of days. It will intermittently cool but most of the time, but it feels like the compressor isn't working. If I press the a/c switch in the cabin, I will feel the idle rise as if the car knows the a/c is kicking in, but no cold air or sound that the a/c system is working. It will work sometimes, and it will blow cold air for several minutes but it does have a hard time going back on once it cycles. I changed the cabin filter and it didn't help.
Could it be the compressor or the compressor's clutch?
Old Oct 22, 2010 | 08:29 PM
hogwylde's Avatar
Sounds like the compressor to me.
Old Oct 22, 2010 | 08:30 PM
Oofie's Avatar
ugh, I was hoping it's not the compressor. It's a $500 part ($350 from bernardi)
Old Oct 28, 2010 | 09:42 AM
rubixdimension's Avatar
Check electrical to the compressor first, make sure it's getting a good connection for power. It sounds like the clutch isn't engaging consistantly.
Old Oct 28, 2010 | 04:21 PM
Oofie's Avatar
Thanks for the tip. However, now that it's not raining in San Diego anymore, it seems to be running properly again. It's slow to start blowing cold air from a cold start, but it's working again.
Old Oct 28, 2010 | 04:24 PM
Perrenoud Fit's Avatar
It sounds like a low charge. which means a rock may have damaged the condencer.GL
Mike
Old Oct 28, 2010 | 06:43 PM
Oofie's Avatar
Mike, sorry I wasn't clear with my post but it works great again. It's a bit slow to cool when the engine is cold, but a/c is normal once engine reaches running temp.
Wouldn't a low charge mean it won't engage the compressor/clutch at all?
Old Oct 28, 2010 | 07:14 PM
yup, I just said that bcuz most prob. w/AC is due to the thin condencer. Then my second thought would be electrical the clutch, switch or wiring. You could jumper the clutch w/12v and that would verify if it was the clutch or not. Keep us posted this is what I really like is the prob. solving here. GL
Mike
phybere
May 29, 2018 11:46 PM
taxonomy
Jun 17, 2017 10:08 PM
Cremacious
Mar 11, 2016 03:57 PM
MorganKl
Jul 1, 2013 01:49 AM
elmo
Aug 12, 2005 11:34 PM
