Spotlight laminate - Cheap & Easy !
Old Nov 21, 2010 | 04:35 AM
VodkaAlan's Avatar
I wanted to protect my spotlights from stones but 'Laminex" is not available where I live. Here's my solution. Pic 1 - Buy a yellow plastic ring folder from any stationery store . Pic 2 shows that it's 90% transparent. Cut a piece out, remove the spotlight cover and place behind ( Pic 3 ). Replace cover ( Pic 4 ). The plastic is held in place by the cover. Total cost - US1.50. Total time to install - 20 mins. Time will tell if it discolours ( or melts ! ) but there's enough material to do both spots 4 times !! so if it fails miserably it's not been a major cost.
Old Nov 21, 2010 | 08:42 AM
eyepon's Avatar
wont that melt over time?
Old Nov 21, 2010 | 10:28 AM
Blueskulker's Avatar
I would imagine the transparency, or state of the material would change with exposure to the weather. Post pics after abut 6 months.
Old Nov 21, 2010 | 02:59 PM
jnesselroad's Avatar
way to go for creativity, but like the others, im not sure it will hold up. you can buy lamin-x from one of the guys on here in thr classifieds or i think decal dude sells it.
Old Nov 22, 2010 | 04:41 AM
VodkaAlan's Avatar
Thanks for the replies. The plastic won't melt, initially it softens then hardens with the heat. For 12 years I've been using a similar materiel as coloured filters in 12v spotlights in a commercial bar - these lights are on for 10 hours per day, 7 days per week. After about 4 months some of the colour bleeds out around the center. However, I don't use my car every night and don't always have the spots on when I am driving, plus there's cool air blowing against the plastic when driving so I think I'll get at least 6 months usage before having to replace them ( which is a 15 minute job ) . As the A4 folder will do both spots 4 times it means that I've protected my spotlights from stones for 2 years for USD 1.50 - I can live with that, I'll keep you posted.
Old Nov 22, 2010 | 05:54 PM
hkfooey's Avatar
Very creative (and not to forget economic!).
Did you just take out the whole unit by removing the screw at the front?
Planning to do mine soon. Thanks!
Old Nov 23, 2010 | 03:22 AM
VodkaAlan's Avatar
Hi khfooey. My spots were supplied and fitted by Honda but they're not Honda original so I don't know if my fixings are the same as yours. Look at my installation photos - on Pic 4 you can see one screw hole, the other is lower down on the other side. By removing these the cover comes off ( Pic 3 ) and I don't have to touch the spots. Hope this helps
raymondchen625@gmail.com
Dec 7, 2015 03:31 PM
TommyMadison
Dec 28, 2013 03:27 PM
Grayfox
Aug 17, 2012 09:16 PM
cruiserandmax
Nov 24, 2009 09:45 PM
boyetssilverfit
40
Nov 13, 2007 12:19 AM
