My projected headlights (GE exclusive)
Old Dec 22, 2010 | 01:37 AM
JJIN's Avatar
Got my projectors in my headlights after much thought of whether the H1 or D2S morimotos were the way to go for my retrofit.
after much thought and weighing a bunch of pros and cons i came to the conclusion that the H1's did outperform the D2S version in every possible way in terms of sheer output and light spread.
The only draw backs to the H1 morimotos is the mounting and the bulb choice is limited to rebased philips or after market cheap chinese bulbs. i, however opted for the philips bulbs for my setup and i couldnt be happier of the brightness and output.
to achieve maximum oem-ness i have painted the reflector bowls in titanium silver and the shrouds are painted a tint darker than the reflector bowls to have that quality factory finish.
here are some cheap droid quality pics for yous.
dont mind the driver's side cutoff i have to take the projector out and tweak with the shield some more.
if anyone local or within a 40mi radius needs help hands on, on how to take apart your bumper/headlights, let me know. i would be more than willing to help out a fellow member. just pick up the tab for lunch/dinner/johnny blue on the rocks.
Old Dec 22, 2010 | 01:48 AM
thefit09's Avatar
I have my headlights apart (an extra set), prepped and painted, and have had my bumper off before. I'm just scared about mounting the projector. How did you figure out where to make the mounting points in the bowl, and how to figure out wiring? Looks good btw.
Old Dec 22, 2010 | 02:00 AM
JJIN's Avatar
theretrofitsource has it all. wiring made simple with their harness. D2S or amp style ballast and mounting points... if you are going the fx-r or fx35+fx-r lens you should use the wall cuttoff marking method to align. to mount just use dremel and some long thin bolts with nuts to level out the projectors.
Old Dec 22, 2010 | 02:22 AM
thefit09's Avatar
Yeah, I have the fx35 kit from the retrofit source. My question is, how did you know how deep to mount the projector in the bowl? Doesn't the back of it need to align so that it can wire up and still keep the seal?
Old Dec 22, 2010 | 10:41 AM
Java^FiT's Avatar
just curious where did u get your extra set from. are the direct oem from honda or you bought them from someone.
Old Dec 22, 2010 | 12:04 PM
hkfooey's Avatar
JJIN - how long did it take you to install them?
Old Dec 22, 2010 | 12:38 PM
JJIN's Avatar
It took me approximately 6hrs for tge inital install with headlight bake time. I can do tge install now within 4hrs because I know where everything is.
Old Dec 22, 2010 | 03:56 PM
jdmjunkie561's Avatar
Damn wish I was near u or u near me to do this!!! I would love the retrofit !!!
Old Dec 31, 2010 | 06:49 PM
fitandform's Avatar
legit retrofit!
cgs2000
Nov 7, 2017 04:21 PM
Blackbeard
Sep 30, 2012 11:07 PM
khanhdom
41
Sep 6, 2010 01:22 AM
Stormtrooper
Jul 26, 2009 04:37 PM
halfmoonclip
Sep 3, 2008 08:52 PM
