makin stuff
Old Jan 4, 2011 | 12:10 AM
fitisbamf's Avatar
makin stuff
bored and having found an engine tq dampner from a eg6 i made mounts to attach to my ge8.... LOOK
Old Jan 4, 2011 | 12:35 AM
Goobers's Avatar
And.... what does it do? o.O?
Based on the name, "tq dampener," I assume it's to prevent the engine from trying to twist its way out of the engine bay when in (low?) gear and you are pressing the gas? I've seen engines rock around in the bay when the gas is pressed (even in parked or neutral), so I kinda see what its for.
I guess my real question is... any noticeable "improvement"?
Old Jan 4, 2011 | 12:38 AM
hayden's Avatar
Should reduce wheel hop, no? Our little engines do move around quite a bit. I think Honda softened the mounts to meet NVH requirements a bit too much.
Old Jan 4, 2011 | 01:11 AM
fitisbamf's Avatar
ya my shifts feel stronger and it feels like it pulls more, i kno it doesnt make hp but it makes it feel like u have more then u do
Old Jan 4, 2011 | 01:48 AM
DiamondStarMonsters's Avatar
That is because more of what you have is transmitted to the ground
Old Jan 4, 2011 | 02:34 PM
Leets's Avatar
My experience, though not in a Fit, is that these can make a difference. It's not going to help you smoke a Ferrari, but it can make acceleration a much smoother experience.
Old Jan 4, 2011 | 02:47 PM
Black3sr's Avatar
Maybe a slow Ferrari.
Nice piece of add-on. Maybe a cap on top of the open pipe? With an H of course.
Old Jan 4, 2011 | 03:42 PM
Java^FiT's Avatar
cool idea, i might have to try this. +rep
Old Jan 4, 2011 | 05:12 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
this is a good find especially for the MT guys.
+ rep
Old Jan 4, 2011 | 05:33 PM
Did you weld the chassis mount yourself? Good Job!
Old Jan 4, 2011 | 05:43 PM
ThEvil0nE's Avatar
this is just what the Fit's engine needs!!!
+reps
Old Jan 4, 2011 | 05:48 PM
hayden's Avatar
Looks like someone might have just created a little side-job business. Well, if they wanted to. Wondering how it will hold up.
Old Jan 4, 2011 | 06:06 PM
The only way I could think of improving upon this would be to mount one closer to the middle as far as the engine block/trans is considered.
My only concern is that by mounting it on the crank pulley side you have now created a pivot point. a second twin damper would be about perfect and keep things from twisting and transmitting yet more torque to the wheels, helping WOT shifts, and keeping wheel hop to a minimum.
Motor mounts would go a long way here as well.
But again, well done OP.
Old Jan 5, 2011 | 10:54 PM
fitisbamf's Avatar
i thought about it but this is a natural pivot point making the engine's head strong enough with out breaking/cracking and to mount a dampener on the other side is no structure to mount it to with out re-enforcement to the tranny, i fear the metal might crack but u are right how ever my motor doent move at all and i mounted the shock level so it resisted more instead of pivot. some thought went into it however i recently made a rear under brace tying the 2 spring buckets together will post pics tomorrow
Old Jan 5, 2011 | 10:59 PM
fitisbamf's Avatar
if interested pm me and we could talk about parts
and i did cover the hole wit a spiky thing i found idk looks kool
Old Jan 5, 2011 | 11:17 PM
There are some parts you could make that there is a market for, like serious modders. Stuff like solid motor mounts, solid subframe, shifter and suspension bushings, catch cans, sway bar links and chassis bracing... Shifter knobs if you have a lathe that will let you tap threads.. I could go on and on haha
Hell you could make them for yourself first and then gauge interest! Take a picture of your spikey cap thing!
Old Jan 5, 2011 | 11:18 PM
I think as it is, for 90% of users that should be perfect.
I'd love to see that brace!
Perrenoud Fit
Oct 17, 2022 06:20 PM
vinnymac
Dec 10, 2015 02:09 PM
vinnymac
Jun 9, 2011 08:39 PM
fitisbamf
Nov 22, 2010 06:38 PM
Mr08FiT
Jun 19, 2009 11:29 AM
