Looking for VSS signal
Old Jun 16, 2006 | 07:02 PM
timster's Avatar
Anyone know where to find the VSS signal on the Fit for Navi hookup?
Thanks
Old Jun 17, 2006 | 03:55 PM
spider2k's Avatar
violet/white in the radio harness.
Old Jun 18, 2006 | 09:11 AM
sillypuddy's Avatar
Someone that Posts too much
serious? is in the radio harness? thanks
-joe
Old Jun 18, 2006 | 09:37 AM
spider2k's Avatar
thats what i have listed from directed. alos u can see it in the wiring pinout listed in the aux input threads.
the radio likely has the automatic volume adjustment that turns the radio up and down depending on speed to compensate for road adjuting ambient noise.
Old Jun 18, 2006 | 05:03 PM
p11wrg's Avatar
in the euro model, I took it from the ECU. Blue Yellow wire.
Al.
Old Apr 1, 2007 | 10:40 AM
thr3's Avatar
What about backup indication?
In addition to the VSS wire, the AVIC-D3 needs to tap the backup light wire. Is there a place to tap this somewhere near the dash?
Old Apr 1, 2007 | 12:20 PM
kps's Avatar
kps
Honda Fit Forums Moderator
If you mean backup as in power-when-the-car-is-off, that's A17 white/red on the radio connector. If you mean backup as in transmission-in-reverse, that's a green/black wire somewhere in the 2nd or 3rd harness connector from the top of the dash fuse box.
Old Apr 1, 2007 | 01:26 PM
thr3's Avatar
backup indication
Backup as in reverse and the white tail lights come on.
Thanks for the quick reply.
I think the last signal that I need for the AVIC-D3 is the parking brake indicator. I'm sure there's a microswitch somewhere near the handle itself, but I'd like to tap the lead as close to the headunit as possible to avoid a long wire run.
Old Apr 6, 2007 | 09:29 PM
FitSport2007_5spd's Avatar
Thr3 - did you find this wire in the end? Are you using the bypass hack?
Old Apr 7, 2007 | 09:22 AM
thr3's Avatar
Avic-d3
I haven't found it yet. I still haven't purchased the AVID-D3. Like everyone else, I'm waiting on the dash kit. I'm trying to get all the required information to decide whether to put this in myself or to use an installer. If all of the required leads are close to the head unit, then it shouldn't be too hard to do myself. The one piece that still bothers me is the GPS antenna. I haven't seen an example of this installed on the Honda Fit.
Old Apr 7, 2007 | 10:40 AM
kps's Avatar
kps
Unfortunately the service manual lists two different colors for the parking brake wire -- green/red or green/orange. (I don't have the electrical manual.) In any case the harness appears to run along the console and then up behind the radio before branching off to the gauges, so you can probably tap it there if you can identify it.
simplelibrarian
Jun 15, 2017 10:56 PM
thebluepotato
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
21
Mar 22, 2015 06:15 PM
Pjbrady
Mar 4, 2015 08:42 PM
hellgiver
Sep 10, 2014 09:26 AM
BamaBR549
Nov 12, 2007 10:56 PM
