Yellow corner lights as DRL?
Old Feb 14, 2011 | 11:39 PM
WhiskeySix's Avatar
I disabled my DRL by pulling the associated fuse, and was thinking I'd just run w/ the yellow parking lights on.... or whatever they're called. Unfortunately they're pretty small, dim bulbs. Does anyone have any thoughts about how we might get those suckers bright? I know some GM cars have those as the DRL's:
I'm not too worried about the wiring... mainly about the bulbs... any thoughts?
Old Feb 15, 2011 | 11:57 AM
WhiskeySix's Avatar
Actually - thinking about this a little more... We have three lights in each cluster, the headlights, the turn-signals, and the parking-lights. The turn-signals are yellow and very bright. The parking-lights are yellow, but less bright.
Maybe I'll take a look at what's going on there and swap the blinkers for the turnsignals... so the turn-signals will be powered by the parking-light circuit and the blinkers will toggle the little yellow parking lights... hmmmm....
thoughts?
Old Feb 15, 2011 | 12:51 PM
JDMxGE8's Avatar
I changed out my OEM corner light bulbs to PIAA Plasma Ion Yellow ones. They're pretty bright.
Old Feb 15, 2011 | 02:25 PM
ThEvil0nE's Avatar
I use MTK 8w replacements. Definitely brighter than piaa plasma 5w. No heat issues.
Another option you could do is mod your turn signals. http://img38.imageshack.us/img38/6404/dsc0232medium.jpg
Replace the socket to accept dual filament and wire to run DRL. The sockets can be found all over ebay.
Old Oct 21, 2011 | 09:54 PM
ktyler's Avatar
Another option you could do is mod your turn signals. http://img38.imageshack.us/img38/6404/dsc0232medium.jpgcorner light
Apologize for reviving this up but this stuff looks cool to me. where can i find one...for how much? I seen an actual one with my buddy but searched over the internet and ebay has lots of corner lights to show. don't have the idea which one to pick...any inputs about it?
Old Mar 11, 2014 | 08:35 AM
luismycorreo's Avatar
This is my solution and works for me
I bought here
NEW! Free shipping 2pc/lot LED car T10 cree 50W ,sliver case high power car led T10 reverse ,tuning light led,T15,H1,H3-in Light Source from Automobiles & Motorcycles on Aliexpress.com
The light is very brilliant, now running for one week and everything is OK
The bulb touch a little bit the plastic on the headlight, however the heat on the leds is not enough to melt them, I'm pretty sure
Disclaimer: I'm not responsible for any bad experience with this seller
Old Mar 12, 2014 | 02:40 PM
WhiskeySix's Avatar
I bought here
Nice! What color are those? White light?
Old Mar 13, 2014 | 11:05 AM
They are PURE WHITE light and are so brilliant like A REAL DRL
I would recommend you
Luis
Old Jul 9, 2014 | 07:12 AM
gd3~fit's Avatar
They are PURE WHITE light and are so brilliant like A REAL DRL I would recommend you Luis
Any issues with heat and it touching the inside of the headlight cover? I want to do this but with amber color.
Old Jul 9, 2014 | 07:46 AM
DWils's Avatar
The color of the LED shouldn't affect the amount of heat that little bulb produces.
Old Jul 9, 2014 | 09:12 AM
I think yellow color produces less heat, don't know exactly may be an expert can confirm.
However if you're thinking to use as a DRL the small corner lights is not a good idea in a SUNNY day
In my case, those small but powerful LEDs produces a lot of heat, but until now the Headlight Assembly is not melted, so I think it will resist without any issue.
Luis
lidoshorty02
28
Apr 5, 2013 10:41 AM
MEATBABY
Apr 26, 2012 02:15 PM
cgpEJ6
Jul 31, 2010 11:44 AM
xonexlifex
Jul 30, 2010 03:45 AM
Draako
Nov 5, 2008 09:41 AM
