please advice on wheels offsets.
Old Mar 2, 2011 | 10:28 PM
Azizul Zulzaha's Avatar
hi im getting a new rim. still undecided on the size seems theres so much rubbing issues. also i will install some high-low soft-hard adjustables.
therefore please help me with this setup, in order not to have any rubbing issues.
What is the car stock rim offset?
i want the sidewall of the rubber to be aligned with the side wall of the car body.
but without rubbing.
195/50/16 - rims should be what offset? 16x??? offset ???
195/50/15 - rim should be what offset? 15x??? offset ???
i love the look on this ride by silverjazz77 guy.
https://www.fitfreak.net/forums/2nd-...r-pics-10.html
195/50/16
16x70jj offsett 44
the setup is exactly like i want.
question, will the setup be affected by different adjustables?
i want that exact look, and no rubbing.
Old Mar 3, 2011 | 11:54 PM
skinny's Avatar
it would be wise to decide if you are lowering the vehicle as well...and if so, what will you use? stock, springs or coilovers? that is a huge factor that may decide whether you'll rub or not as well.
Old Mar 4, 2011 | 10:09 AM
rhyneba's Avatar
See this thread here.
b
Old Mar 21, 2011 | 03:21 AM
i got my taiwan made SSR type F 16 inch, offset 42.
wrapped with potenza andrenaline re001 205/45/16. i should have opted for 205/50/16...now my wheels seems like a 15inch...
with coilover, no rubbing even with full load (cannot see behind)...also no rubbing. front 2 finger, rear 3 finger...
Old Mar 21, 2011 | 03:36 AM
doctordoom's Avatar
Supervillain
wait, is it made in taiwan by SSR, or made in taiwan by another company?
Old Mar 21, 2011 | 09:08 AM
Bthasht's Avatar
If your on coils let that finger gap be 1/2 finger for the best look. Imo
Old Mar 22, 2011 | 12:59 AM
that is for the front only, or both front and back?
im afraid that if i go lower, my front camber will be off...
with 2 finger gap at the front, i have adjusted the front camber to -0.5 both sides...
Old Mar 22, 2011 | 01:01 AM
made in taiwan by other company...basically its a replica..cheap...hopefully anti-theft...
p nut
Sep 11, 2014 04:15 PM
wackyflik
May 29, 2012 09:04 AM
ccl088
Aug 1, 2011 09:41 PM
braziers
Jan 30, 2009 05:51 AM
