differential ratio (Standard vs Sport)
Old Mar 18, 2011 | 01:05 PM
mraroid's Avatar
Hi again....
I see that the 2011 Sport has bigger wheels than the standard 2011 Fit. Can anyone tell me if the differential ratio in the transmission is different between the standard Fit and the Sport Fit? The standard Fit has 15" wheels, and the Sport has 16" wheels.
Is the transmission identical in the standard and Sport? I would think that the wheel size would effect the differential ratio, but I can not find the answer to this question.
Anyone know?
Thanks
mraroid
Old Mar 18, 2011 | 02:39 PM
D50boy's Avatar
No differences base or sport. Only 2 transmissions are available- 5 speed or auto.
5-Speed Manual Transmission Gear Ratios: 1st: 3.308, 2nd: 1.870, 3rd: 1.303, 4th: 0.949, 5th: 0.727, Reverse: 3.308, Final Drive: 4.62
5-Speed Automatic Transmission Gear Ratios: 1st: 2.996, 2nd: 1.679, 3rd: 1.067, 4th: 0.761, 5th: 0.552, Reverse: 1.957, Final Drive: 4.56
Wheel size makes no difference- tire size does. As long as the overall diameter of the tire is the same, you'd see no difference with a 13" wheel or a 19" wheel. One rotation will cover the same distance.
Old Mar 18, 2011 | 04:25 PM
mraroid's Avatar
transmission gear ratios
D50boy....
You are The Man! Thanks so much for the good info.
mraroid
Rollerboots666
Racing
May 20, 2015 05:55 PM
mxl180
Dec 25, 2014 10:17 AM
B-Blue
Mar 30, 2010 10:34 PM
sirgolf82
Jul 23, 2006 01:21 AM
tywen
Apr 24, 2006 09:50 PM
