Headlight Voltage Drop
Old Mar 21, 2011 | 06:28 PM
jadr09fit's Avatar
Some data on voltage drop through the factory headlight harness.
First, a note on wiring. Honda put the pink wire as the common ground, with the black wire as the low beam feed and the green wire as the high beam feed in the H4 headlight plug.
Onto voltage drop, measured with my Harbor Freight digital multimeter:
Car off:
Battery: 12.5 volts
Headlight: 11.8 volts
Car on:
Battery: 14.5 volts
Headlight: 14.3 volts
I would have thought the voltage drop to be far more, given the spaghetti size of the wire. Interesting results, to say the least.
smeister
31
Aug 3, 2014 04:18 PM
1toughfit
Feb 14, 2014 01:29 AM
Jutboy
Sep 13, 2012 11:44 AM
mrDFWmechanic
Oct 14, 2009 07:37 AM
Tony Baker
May 4, 2005 04:44 PM
