GD3: Radio Reception problem FIX
Old Apr 11, 2011 | 05:59 PM
chunkylover8200's Avatar
If you have an aftermarket radio and expireincing reception problems, try this out:
Originally Posted by Dave23703
for those of us who would like a straight answer on where to connect the antenna booster lead, which MUST be connected to use the radio....
The Blue wire from the powered antenna harness should be connected to the remote turn on/power antenna/amp turn on lead of the new head unit, it will sufficiently power the antenna booster; IF you don't have one of these connections, splice into the 12 volt switch on the ignition not the 12 volt constant/memory.
This applies to all newer Honda models.
and here is a video i made
YouTube - Honda radio reception problem fix
Old Apr 11, 2011 | 06:00 PM
Potential sticky?
Old Apr 12, 2011 | 12:44 AM
artieman's Avatar
This doesnt resolve the issue we are having with the oem radio
yellow wolf
Oct 24, 2015 05:51 PM
SHOELAC3D
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Jul 10, 2014 02:56 PM
damoaten
Feb 28, 2013 11:09 AM
AXEL
Sep 16, 2008 01:51 PM
Crawly
May 9, 2008 11:17 PM
