normal rpm when idle
Old May 14, 2011 | 09:41 AM
ryu's Avatar
ryu
Please can someone advise if 1k rpm is normal on idle?it will start at 1.5 when engine is cold then after 5 mins or so it will be at 1k.in normal driving when i shift gears rpm kicks at 1.5t rpm then go down at 1k.is there a problem and what is the solution.
Old May 16, 2011 | 12:19 AM
airwicc's Avatar
I'm pretty sure 700 - 900 rpm is average for most Fits. My idle personally is around 700 - 900 rpm with lights off and on. There is a thread on here that tells you what normal idle is on the Fit but I can't seem to find it. 1k rpm idle seems a bit too much. Check the timing maybe?
Old May 16, 2011 | 11:38 AM
Fitguy07's Avatar
Yeah, if the car is wamed up to normal operating temperature and it's still idling at 1K, that's too high. Maybe a bad Air Temperature Sensor of PCV Valve? Do our cars have an Idle Air Control valve?
Fluxmerc
Sep 22, 2012 02:40 AM
x_25
Feb 13, 2012 01:58 PM
phogroian
Nov 3, 2010 10:01 PM
spartan-lee
Dec 28, 2008 12:59 AM
bibby
Apr 27, 2006 05:23 PM
