Help with rear strut top!!!!
Old May 16, 2011 | 06:02 AM
fillit's Avatar
Hey guys,
I was removing my rear sway bar and I was really stupid as i forgot to put the bushing and nut back onto the strut top. I went for a small 2 min test drive as I was taking something out of the car and wanted to test it. Now the car was feeling abit wonky as i didn't put the nuts in. However now i've come to realise that on the right rear strut top the cylindrical (Washer?) thing has come up.. i put a socket over it and lightly tapped it down and it seems to be working. I'm reasonably sure I can get it back into the same position. However i want to make sure that i'm doing the right thing and not damaging the car.
I've taken some pics, sorry about the bad quality it's dark outside ><.
And this is the strut top on the left side, hopefully i've put it all back correctly, going to tighten it abit more tmr morning.
Old May 16, 2011 | 11:46 AM
im not sure wat you're saying but if all fails, just take both sides off again and re-install. Fit's a super easy to do especially the rears.
Old May 16, 2011 | 09:17 PM
fillit's Avatar
basically what happened was that i forgot to put the bushing and nut back in, when i did 3 right turns the pressure on the shock absorber pushed the cylindrical washer upwards as there was no bushing to stop it. now i was wondering if i could just slot the cylindrical washer back into position and tighten everything up again.
Old May 16, 2011 | 10:43 PM
Goobers's Avatar
are you talking about the parts numbered '6'?
FYI, the parts boxed in as #2 go under the car, where the other three parts on top go on from the other side of the sheet metal (from inside the car).
I say, just do what kenchan said... pull the shock out and start over with the reinstall.
Old May 17, 2011 | 04:00 AM
fillit's Avatar
yes part number 6, i raised the car to check it out and it was just a washer, and i managed to return it to it's original position and tied everything back up. took it for a test drive and all seems well so far .
revd34
70
Jul 15, 2009 02:40 PM
keepitpg
Jan 19, 2009 04:52 AM
BlazeOrangeFitTuner
Jan 12, 2008 05:53 PM
MNfit
13
Jan 1, 2008 04:41 PM
