2007 GD3 Sport, 15x7 +42 with tein s-tech - Will it fit?
Old Jun 3, 2011 | 06:24 PM
dustinb's Avatar
Hey folks. I've been looking at wheels since I bought my fit a few weeks ago. I've been reading on this forum, and have decided to stick with 15" and the 195 tire. I was looking at 6.5" wide rims just to keep from rubbing, but I came across a set of 5zigens that I really like. The specs are them are: 15x7, +42 or +33 offset, 14lbs. I'll be putting the 195/55/15 tires on the rim. My main concern is rubbing, as I'll be installing a set of tein s-tech springs on the car. Will the 15x7 +42 rub? Ideally I'd like to go for the +33's just to have a more flush look, but I'm guessing those will rub for sure.
Here's a pic of the rims:
Thanks for the help!
Old Jun 3, 2011 | 11:22 PM
dustinb's Avatar
Alright after doing much reading, it appears that what I'm really going to need are +45mm wheels if I want to avoid rubbing. I at some points will have quite a bit of weight in the car, and i really don't want to start rolling fenders. So can anyone suggest some wheels either 15 or 16 that come in +45 offset? I seem to be having a hard time finding them.
Old Jun 4, 2011 | 02:41 PM
Blackbeard's Avatar
Smile I think you are confused...
The original (sport) wheels are 15X6 +53, on my GE I put 15X6.5 +40 offset with no problems (195/60/15 tires though). The wider the wheel the less offset you need. You should be fine with either the +33 or +42 in 7 inch width.
Old Jun 4, 2011 | 05:14 PM
dustinb's Avatar
Hmmm, thanks for the feedback. I think I've settled on the 5zigen gn+ in HMC.
Old Jun 5, 2011 | 12:05 AM
feared's Avatar
you should be good if u stick with the 195 tire. Last i checked on 5izgen wheels, they're currently not in production, so not sure on the availability
Old Jun 5, 2011 | 02:42 AM
DreaMv's Avatar
you wont rub at all.. i have 195/55 with +38 and its goood
Old Jun 9, 2011 | 02:26 PM
Bthasht's Avatar
I run 16x7 +40 on tein. 205/40. Of course I have no fender lips,i cut them out. Fender rolling can be done for about $200 all corners. Well worth it to fit your desired wheels.
Manga_spawn
Jul 14, 2011 09:03 PM
fitfreak2
Sep 17, 2010 10:33 PM
mangberto
Jul 2, 2010 09:41 PM
GTornado
Jul 28, 2009 08:19 PM
southwilrise87
Sep 5, 2007 09:04 PM
