My Tein S-Tech sagged on the right side
Old Jun 30, 2011 | 09:52 PM
Jazz_Pinkz's Avatar
hello, does anymone here have the same problem as me ?
the spring that i buoght was used, but i didn't notice any problem until a month ago, it's about a year an a half since i use this springs, by the way, my jazz is Right Hand Drive.. that's why i'm curious why the right side is shorter than the left side ??
and, is there something i can do to fix this ?
Old Jul 2, 2011 | 05:53 PM
feared's Avatar
how much difference is the drop?
Old Jul 2, 2011 | 11:42 PM
Goobers's Avatar
Try swapping left<->right sides..
The reason yours sags on the right... is the same reason many USDMs sag on the left... because of YOU, the driver. You are a constant source of weight for one side.
The only way to prevent the "mismatch" is to even out the weight. Either you lose weight, or you add weight to the other side of the car.
Old Jul 3, 2011 | 09:26 AM
Jazz_Pinkz's Avatar
the drop is 10 mm, or 1 cm..
ok, thank you very much for your suggestion, i'll try to do it.. it's very make sense.. i didn't realise that at first ^^
bjosuesr
3rd Generation GK Specific Suspension & Brakes Sub-Forum
21
Mar 25, 2022 08:48 PM
FitterThanASnicker
Aug 27, 2018 10:31 AM
alexfree05
Feb 27, 2009 09:43 PM
GTornado
Dec 3, 2008 03:27 AM
GD3 IS GO!
Jul 21, 2008 10:36 AM
