Ball bearing turbo for our Fit?
Old Jul 8, 2011 | 06:38 PM
clanbuster's Avatar
1) Is there any ball bearing turbo that can suit to our FIT 1.5?
2) if no have ball bearing version then For TDO4 vs TD03, which is better
for our ride?
- currently i using TD04 and i suspect my turbo got problem, intent to change new one but when to afew mechanic and advise me to TD03 due to my 1500cc engine is too small for TD04. how you guy comment?
Old Jul 18, 2011 | 08:53 AM
clanbuster's Avatar
i change my mind. is either TD04 or GT15?
I'm sure GT15 will suit our displacement 1500CC as clearly status at Garrett website, what abt tD04? i still can't find the chart and info from them.
Mostly tD04 for 2000cc and above ( which i had found)?
Old Jul 23, 2011 | 06:43 PM
DiamondStarMonsters's Avatar
The GT25R and 28R/28RS are all ball bearing. What flange is on your manifold?
I would put little stock into what displacement Garrett recommends a given turbo for. They are making assumptions in doing so.
Also.. enjoy buying new center sections instead of rebuilding if you go ball-bearing.
The turbo you will be using will likely be so damn small any real world difference in lag or transient response between the two will be negligible for your purposes.
Old Aug 22, 2011 | 12:03 AM
whtsjdm's Avatar
This. Honestly, with a turbo that small, the spool time is going to be negligible. Save your money and stick with a journal bearing. td04 is perfectly fine for your setup. I don't know what these mechanics of yours are talking about. A td04 is extremely small.
porkchop
13
Feb 25, 2009 09:31 PM
tonyd3773
Jul 26, 2008 03:43 PM
tonyd3773
Jun 15, 2008 11:28 PM
tonyd3773
Apr 12, 2008 12:34 PM
tonyd3773
Mar 12, 2008 04:40 PM
