Help with lunuts please!
Old Jul 16, 2011 | 12:52 PM
08fithappy's Avatar
Help with lugnuts please!
Well guys i bought my XB used with the lugs and wheels thats on it. Well i tryed to get the lugnuts off and the key striped. I should have looked at the key more closely before buying the car. But i did notice it was in ruff shape last week. Well here is a pick of the lug nuts any suggestions as to how to get the lugs off now or get a replacement key. I have no info on these lugs and no contact with the owner bought this car 9 months ago. Now i did find this site based off the size on the lug being M12x1.5 so would this key work for mine do you think Wheel Adapters|Lug Nuts|Wheel Spacers it looks just like my key and the lugs look the same to me just different color
Old Jul 16, 2011 | 03:21 PM
Hootie's Avatar
Those look like the Gorilla Key lug nuts that Discount Tire typically uses with aftermarket wheels needing cone tipped lug nuts. You should pop over to one (if there is one in your area) and pick up the spline key for them.
Old Jul 16, 2011 | 09:28 PM
Fitting's Avatar
Standard spline drive lugs/key. Those keys are all over ebay or ask around for a local member that might have one you can borrow.
Old Jul 16, 2011 | 10:41 PM
90 DGRZ's Avatar
all true^ thats the most common spline key lug nut. for now, you can CUT the part of the tip away that stripped on the key and you can still use your key since the splines go all the way through to the top.
Old Jul 16, 2011 | 11:35 PM
08fithappy's Avatar
Thanks guys i found a new key online. The hole slpine striped off of the key some how. So i just borught a new one with new blue lugs here is a pick they were $35 Shiped
Bossharp
Aug 2, 2015 01:57 AM
mike410b
Oct 11, 2011 05:11 PM
chinkyy
Mar 18, 2009 09:45 AM
vlam
Greater Calgary Community
May 12, 2008 10:41 AM
mugenfit79
Apr 30, 2008 07:55 AM
