h9 bulbs
Old Jul 2, 2006 | 10:54 PM
FikseRxSeven's Avatar
h9 bulbs
after all of the hype of the brighter light, i am disappointed to say that i tried to install an h9 light bulb for the past 20 mins and the key will not line up. i will try again tomorrow when there is more light out
Old Jul 2, 2006 | 11:05 PM
XBriteHID's Avatar
h9? are u trying to install that on a fit if so you are not using the right bulbs
Old Jul 3, 2006 | 01:02 AM
Illusive's Avatar
H9 is for the fogs if I remember correctly...
Old Jul 3, 2006 | 01:21 AM
XBriteHID's Avatar
If its for the fit then the fogs are h11 not h9
Old Jul 3, 2006 | 01:25 AM
Illusive's Avatar
my bad, not planning to change my foggies anytime soon anyways :P
Old Jul 3, 2006 | 04:07 AM
spider2k's Avatar
Originally Posted by XBriteHID
If its for the fit then the fogs are h13 not h9
i thought it was h11 for the fogs...
Old Jul 3, 2006 | 09:26 AM
h11's are for the fog lights, but supposedly the h9 has the same key as the h11 and produces 2100 lumens compared to the 1350 produced by the h11's.
i read somewhere that the key difference is so small that you can use the bulb in place of the h11, and i proved it wrong last night. ill keep playing around with it to see if i can get it to go in.
visually comparnig the two bulbs, they are almost identical to each other except for some certain differences with the key, and the tip of the h11 bulb is covered. everything else seem to be geometrically the same, including the distance of the filament from the base.
Old Jul 4, 2006 | 05:35 PM
gguest's Avatar
By the book; the correct ones are H11. Although I did put H9's on mine. I had to do a little minor cutting in the fog light housing bulb slots and a minor trim on the plug on the bulb. Light output is much better and I have had no problem with the 10 extra watts or oncoming drivers.
Old Jul 4, 2006 | 05:54 PM
LiL Wee FIT's Avatar
Darn, have to mod the housing itself?
I was hoping to mod just the H9 bulbs....
Old Jul 4, 2006 | 08:53 PM
brdss's Avatar
What was the minor cutting that you had to do? I am thinking of upgrading to the H9 bulbs myself! How long did it take you to swap them?
Old Jul 5, 2006 | 11:28 AM
can you advise me on which prongs did you have to modify? do you think that if i modify the prongs on the base of the bulb enough, i dont have to modify the housing for the fog lights?
Old Jul 6, 2006 | 07:22 AM
gguest's Avatar
I made a couple of the slots wider on the housing because it was some kind of hard plastic although you could make the metal tabs smaller in width on the bulb and do the same thing. I did have to cut a small piece of plastic off the plug end of the bulb with a utility knife. I used a small metal cutter with a Dremel tool for the housing. I'll see if I can get some pics together.
Old Jul 6, 2006 | 08:21 PM
XBriteHID's Avatar
Why do so much mods when u can get an h11 bulb that will fit just fine without any trimming
Old Jul 6, 2006 | 08:25 PM
Reason for the H9 bulbs over H11 is because the output on the H9 is much greater than H11....
Old Jul 6, 2006 | 09:30 PM
brdss's Avatar
1350 lumens from the H11, 2100 lumens from the H9.
That is why.
Old Jul 17, 2006 | 01:07 PM
if i take a side by side picture of the H9 and H11, would you be able to show us where to cut the base of the bulbs?
thanks
Old Jul 17, 2006 | 03:40 PM
gguest's Avatar
Yes I could do that.
Old Jul 20, 2006 | 11:05 PM
sorry, i dont know where my digital cam is so i used my phone, and it came out a lil blurry
Old Jul 21, 2006 | 01:12 AM
oh yeah... the blue bulb is the H11 and the clear is the H9
Old Jul 21, 2006 | 06:07 PM
gguest's Avatar
I'll work on a picture to post this evening.
