Spoon Blue Rear View Mirror Fitment
Old Sep 6, 2011 | 10:09 PM
cgpEJ6's Avatar
So I just got my Spoon blue rear view mirror today and have some questions about installing it. Everything seems to say that the mirror just sticks on. My problem is that if I just stick this thing on it leaves a big gap from the curve of the mirror and the edges are a little sharp. Is that just how everyone is doing it? If that's as good as it gets I'm putting it back in the box and staying OEM. It seems to me that it would be a lot better if you removed the OEM glass and replaced it with the Spoon glass. I saw someone mention doing that in another thread but there wasn't much in the way of details and I can't seem to figure out how to remove the glass. I don't want to destroy the stock housing pulling it apart. The unit comes with a small suction cup in the package, what is that supposed to be used for? If anyone has any insight, I'd appreciate it.
Old Sep 7, 2011 | 01:05 PM
cgpEJ6's Avatar
Bump, anyone know how to remove the glass?
*edit, just found a thread about baking it… I suppose that could work.
Old Sep 7, 2011 | 11:56 PM
cgpEJ6's Avatar
I ended up just putting it on top of the glass, when it's actually stuck down the gap is a little bit smaller and you don't really notice it much when you're sitting in the driver seat. I'm still kind of disappointed that it doesn't look as OEM as I hoped but at least it will be easy to remove if I get tired of it. It's not bad but I was hoping for a little bit more from Spoon.
Old Jul 10, 2012 | 04:26 PM
AJR Jay's Avatar
The Spoon rear view mirror lens is made to be stick on. As you can see, the lens is convex and included double sided tape to attach onto the current mirror.
I don't know anyone who has remove the OEM lens to install this.
Regards,
Jason @ AJR
Old Jul 10, 2012 | 06:15 PM
Wanderer.'s Avatar
Aw, that's dissapointing
I was hoping this was like a replacement for the stock mirror glass, not a stick on.
Guess i'll stay with my Broadway, it's good to know this though so thanks for posting.
Old Jul 11, 2012 | 04:21 PM
AJR Jay's Avatar
You shouldn't count out the Spoon mirror nonetheless though. Although, it is a stick on, keep in mind, that not only does it have a cleaner look than the broadway, it also increases visibility by about 30 - 40%.
Not only that, but the Spoon mirror also prevents glare from vehicle headlamps from behind.
I used to have a boardway mirror myself, but I actually switched to the Spoon one after because the broadway mirror didn't allow my passenger visor to swing all the way down without hitting the mirror.
Regards,
Jason @ AJR
AdvansCPAP
Oct 27, 2013 01:47 PM
Tofuman
Jul 12, 2013 01:36 PM
AJR Jay
Sep 4, 2010 02:37 PM
Choro-Q_Fit
Aug 28, 2010 10:13 PM
Spyderfenix
23
Apr 21, 2010 12:48 PM
