Honda Fit 2007 Tail Light Cover Replacement
Old Sep 29, 2011 | 05:42 PM
Myorangefit's Avatar
Exclamation Honda Fit 2007 Tail Light Cover Replacement
I got into a minor accident and my tail light cover on the passenger side broke, but the lights are still working. I just bought a new cover for a good price, but I have no idea how to replace it. Help?
Old Sep 30, 2011 | 06:28 PM
Paul79UF's Avatar
There's an access panel in the cargo area that you have to pry off with a small flathead screwdriver.
Then remove the two or three small nuts that hold the tail light assembly to the rear of the car.
The nuts might be 10mm or 8mm, I'm not sure.
Good luck
Old Oct 21, 2011 | 07:45 AM
SaM01's Avatar
Where do u get the cover from ? I also have a small crack in the tail light but dont want to pay to change the whole tail light !
Old Oct 21, 2011 | 12:25 PM
FitCrazy80's Avatar
Myorangefit,
When my friend's Fit got rear-ended, we ended up just replacing the entire tail light assembly as opposed to just the cover. Therefore, this procedure documents how to replace the tail light assembly (you may have to follow it even if you're just replacing the cover):
1) Remove the rear bumper as follows:
  • Remove the clips, screws, and bolts securing the rear bumper.
  • Pull on the rear bumper at the wheel arch areas to release it from the hooks on the side spacers.
  • With the help of an assistant, pull the wheel arch portion away from the side spacer while pulling the rear bumper to release the bumper from the hooks on the side bracket.
  • With the help of an assistant, pull the rear bumper to release the bumper from the hooks on the upper brackets.
2) Open the tailgate and remove the maintenance lid.
3) Disconnect the connectors (A) from the taillight (B).
4) Remove the mounting nuts and the screw, then remove the taillight.
To Install:
1) Installation is the reverse of the removal procedure, noting the following:
  • When installing the taillight, check the gasket; if it is distorted or stays compressed, replace it.
  • After installing the taillight, run water over the taillight to make sure they do not leak.
  • Install the bumper in the reverse order of removal, and note these items:
  • Make sure the rear bumper engages the hooks (of both the side bracket and side spacers) on each side securely.
  • Check for damaged or stress-whitened clips, and if necessary, replace them with new ones.
  • Push the clips and hooks into place securely.
*diagram courtesy of hondapartsnow.com; all rights reserved
Old Jan 3, 2021 | 02:59 AM
Jazzblues's Avatar
Has the OP or anyone managed to remove a taillight lens on a GD, it's clearly removable but it would appear there is some kind of glue holding the lens down?
Heat gun to soften it or just needs a little prying?
ONEDVSMOFO
Aug 31, 2012 01:49 AM
hondafitblue
Jan 12, 2011 01:45 AM
mole177
Jan 5, 2011 11:34 PM
Killgore9998
Aug 31, 2010 05:03 PM
herbalteebag
Jun 5, 2009 04:34 PM
