HKS Supercharger bumps CR-Z to 200hp
Old Oct 3, 2011 | 02:19 PM
ThEvil0nE's Avatar
2011 Honda CR-Z - Back In Black - Import Tuner Magazine
Old Oct 3, 2011 | 02:34 PM
ThEvil0nE's Avatar
L15A hondata tuned... B&D you reading this :D
the long awaited HONDATA ECU...
Old Oct 3, 2011 | 04:07 PM
FitStir's Avatar
hahaha
201 hp w/ HKS Supercharger... I want.
Wraptivo, eeh? hmmm.
Old Oct 3, 2011 | 04:32 PM
blackndecker's Avatar
Yes....yes I am. I'm so jelly.
Old Oct 3, 2011 | 06:52 PM
TurboManGT's Avatar
I'd still like to see this car without the IMA. I just don't want IMA on the cars I drive.
Old Oct 3, 2011 | 07:08 PM
555sexydrive's Avatar
Strange that in the listing of parts, they list HKS' F-Con IS and no mention of Hondata at all except for tuned by in the article. So possibly Doug, Derek and the guys just tuned the F-Con? And not actually have something for the CR-Z or LEA ECU.
Old Oct 3, 2011 | 07:29 PM
Jamy's Avatar
Imagine 200hp in a Fit... *drools*
Old Oct 3, 2011 | 11:40 PM
Good pick up. This means there is no reason we couldn't assemble something similar for the GE. I'm assuming the F-Con is a piggyback tuning solution? All you really need to tune on a supercharged SOHC is air and fuel, right?
Old Oct 4, 2011 | 12:16 AM
DiamondStarMonsters's Avatar
Spark Angle..
Old Oct 4, 2011 | 12:57 AM
I'm guessing that could be controlled with an AEM piggyback as well, right?
Old Oct 4, 2011 | 01:04 AM
Well if you mean the FIC.. yes but without a little tuning fuckery you can only retard timing in a straightforward manner. Otherwise you have to play with IAT/Airflow to make it increase timing at any given point.
Really for a pump gas car, you shouldn't need to advance it anyways. Just fill the gap with boost.
Old Oct 4, 2011 | 05:49 PM
Deleted
10 char
Old Oct 4, 2011 | 05:53 PM
Jamy's Avatar
Ok. There is no way that could be what I think it is.. Could it?
Old Oct 4, 2011 | 05:58 PM
Deleted
10 char
Old Oct 4, 2011 | 06:01 PM
Jamy's Avatar
Originally Posted by blackndecker
Imagine a Fit with 240 TQ at the wheels.
Lol it has to be what I think it is then. So I'm guessing it's the 3 liter? And not the newest 3.5? Cause the specs I found on the 3.5 show 254 ft-lbs TQ.
Old Oct 4, 2011 | 06:55 PM
Deleted
10 char
Old Oct 4, 2011 | 06:57 PM
Jamy's Avatar
I was just throwing out ballpark numbers. I'm not sure if it's the 3.2 or 3.5 liter.
Ah ok. Either way. It's a lot and I kinda want a CRZ now if I can do that. Do you think it'll fit in the GE? It seems too big.
Old Oct 4, 2011 | 07:00 PM
The engine bay should have the same dimensions. The front subframe is identical.
Old Oct 5, 2011 | 11:31 AM
Deleted
10 char
Old Oct 5, 2011 | 01:30 PM
I deleted the pics because of some controversy on another forum....but, I just received word from Brian G that the CRZ k-series mounts should bolt right up with no modification.
