I need some torque specs please
Old Nov 10, 2011 | 12:09 PM
D50boy's Avatar
please delete
Nevermind, I found the info!
Old Jun 10, 2012 | 10:27 AM
bebemaster's Avatar
Why would you do that? Please leave the info you found so others can find it. This reply came up on a google search for me when looking for torque specs and there is nothing here...
Old Jun 13, 2012 | 12:59 PM
D50boy's Avatar
Dang, you registered just to gripe at me!?
Here dude.
http://www.hondafitjazz.com/manual.htm
Old Jun 13, 2012 | 08:30 PM
bebemaster's Avatar
Thanks
That was exactly what I needed. Specifically for the brake caliper torque specs listed here
Front Brake Caliper Overhaul
I thank you and the people of the future thank you.
Old Feb 10, 2015 | 06:54 PM
GC617289's Avatar
Smile Bolt Torques
Caliper body to caliper bracket bolts (8x1.0mm) are 17 ft.lb
Caliper bracket to knuckle bolts (12x1.25mm) are 80 ft.lb
Old Feb 9, 2017 | 05:29 PM
JazzGD1freak's Avatar
I couldn't find torque specs for the flywheel anywhere. Thanks for the manual! From one of the people of the future.
Old Apr 14, 2017 | 02:26 PM
Zardiw's Avatar
Wouldn't it just be easier to post the actual torque value on the front brake calipers when you are replacing the pads.
And fwiw, none of the links posted in this thread actually show a number.......lololol........z
Old Apr 14, 2017 | 02:31 PM
Zardiw's Avatar
The Caliper bracket to knuckle bolts. Are those the 2 (on top and bottom) that you remove to take off the caliper when changing pads? On the 2013 Fit you have to back up the big 3/4" / 19mm nut when taking out the 12MM bolts, cause they screw into something that takes a 3/4 / 19mm wrench......
And I find it hard to believe that little 12mm bolt requires 80 ft lbs.
Old Dec 22, 2018 | 11:17 PM
So it is's Avatar
I know this is a late reply but I was looking into the matter myself. If you click the link there's a small icon bottom left that opens up the diagram showing the parts and torques needed.
So it is
Dec 22, 2018 11:34 PM
MauriceS
Sep 15, 2018 10:49 PM
powerzamcam
Apr 11, 2017 05:27 PM
buttersandpaper
Dec 12, 2013 11:54 AM
Nighthawk_GD3
Aug 16, 2009 07:00 PM
