2nd Gen GE8 Specific Fit Exterior Modifications & JDM Styling Sub-Forum Threads discussing exterior modifications and JDM styling for the 2nd Gen GE8 Honda Fit
2012 Civic shark fin antenna swap on a GE8
Old Dec 19, 2011 | 08:34 AM
09blackfit's Avatar
Over on the CRZ forum someone swapped the 2012 Civic shark fin antenna replacing their HUGE CRZ shark fin.
sunroof installed & fin antenna swapped - Honda CRZ Forum: Honda CR-Z Hybrid Car Forums
My question is... can anyone who has done a shark fin antenna swap on the fit give me some insight into how to remove the fit antenna, how difficult it is, do you have have to drop the headliner or anything else I might need to know.
I was thinking about ordering the 2012 civic antenna. The OEM part (39150-TR0-A01ZD) can be had online color matched for $23.
I know it won't be plug'n play and there will be wire splicing involved, but before I order the part and get in over my head I wanted to see if anyone could give me any advice on this mod.
Old Dec 19, 2011 | 09:52 AM
FitStir's Avatar
I mentioned that thread/mod over in concorde's progress thread. After more research I'm thinking one of the sharkfins from the Civic's (or different model Honda) might be a direct plug and play, but not sure which one, maybe even the one posted. There's another sharfin I think it was from a Civic also which was bigger.
Regardless, from what I've been reading (on crzforums), the headliner is going to have to come out. Now I've seen some members on here re-wrap their headliner just can't recall if their diy's included removal and reinstallation of the headliner, but it's possible to do.
That I would say would be the hardest part, after that from what I've read the oem antenna is held down with a bolt that you unscrew and remove (of course unclip the connector first). Then install the sharkfin (depending on connections you might have to splice). The rubber base acts like a gasket and seals the car so no water gets it.
I've never done this but from everything I've read it's possible, and doesn't sound too hard. If I don't get to it myself, I'll probably just have it installed when (and if) I get the sunroof, and also have them wrap the headliner with perforated leather.
Old Dec 19, 2011 | 02:43 PM
Black3sr's Avatar
Or get a Shark Fin antenna. All done from the outside.
Google them
Here is mine
Old Dec 19, 2011 | 03:07 PM
09blackfit's Avatar
Google them
Here is mine
That does look nice. Were you able to find one color matched or is it simply a "white", "Black", "Silver", etc.?
My vehicle is black, but I would like for it to be honda OEM color matched if possible.
Old Dec 19, 2011 | 03:16 PM
09blackfit's Avatar
Update: I ordered a color matched version from Visual Garage. It seems as though others on the forum have ordered from there with success. I like the design of the 2012 civic antenna, but I'm not interested in pulling the headliner.
Old Dec 19, 2011 | 04:14 PM
Black3sr's Avatar
RIght Visual Garage. that is where I got mine and they paint to match.
Old Dec 23, 2011 | 10:10 PM
pinoyfitpilot's Avatar
got mine off of ebay. was factory painted matched, and shipped from Japan.
Old Jan 11, 2012 | 03:40 PM
09blackfit's Avatar
Just a heads up I ordered my Visual Garage sharkfin on 12/19 and it is now 1/11 and still has not shipped. I emailed customer service on 1/4 and I was told i was at the top of the queue. By the top they must have meant bottom.
Old Jan 15, 2012 | 09:10 AM
BlueBoogers's Avatar
How do you remove the stock antenna? I hope the headliner doesn't need to be dropped.
Old Jan 15, 2012 | 12:20 PM
2012FitFan's Avatar
The Visual Garage Shark Fin just requires you to unscrew and remove the antenna. It installs right over the existing base:
VG Shark Fin Antenna - Installation
Old Jan 15, 2012 | 05:30 PM
Thanks for the link. I'm going to paint my roof black so I need to remove the base itself.
Old Jan 20, 2012 | 04:06 PM
FitStir's Avatar
Thumbs up
If your going to remove the base you will probably have to drop the headliner to get to the assembly (but I'm not 100% sure). If you do drop the headliner might as well go with OEM Honda for the price (imo). Please post pics if you do.
Old Feb 2, 2012 | 11:29 AM
swflej1's Avatar
You dont have to drop the whole headliner. If you pull the rear seat belts (14mm bolts I do belive ) the c pillers... think im forgetting some but anyway you should be able to reach the bolt for the antenna.
Old Feb 2, 2012 | 11:52 AM
FitStir's Avatar
Thumbs up
Thanks for the tip, gonna look in to that when the weather gets a little warmer and I can resume my mods.
Old Feb 2, 2012 | 02:15 PM
Black3sr's Avatar
Why? Why not just mask it?
Old Feb 11, 2012 | 07:01 PM
Does anyone know if the 2012 Civic antenna is AM/FM/XM or just XM?
Black3sr: because I want to get rid of that phallic antenna anyways
Old Feb 11, 2012 | 07:28 PM
Krimson_Cardnal's Avatar
You can easily get to the bolt by freeing the rear edge of the headliner. Problem is the antenna lead is fixed to the base. To free that you need to remove the 1/4 panel trim on the passenger side rear.
I installed an XM antenna under a VG shark and fished the XM lead to the front along the headliner edge.
Old Feb 12, 2012 | 07:32 PM
Cocowheat's Avatar
Just get the shark fin off the FIT EV.
Old Feb 15, 2012 | 07:10 AM
swflej1's Avatar
I got the antenna in yesterday, I'll install it at work today and post pics later tonight. Working a double so it will after 9:30 pm
Old Feb 15, 2012 | 07:14 AM
2012FitFan's Avatar
Nice! Looking forward to your thoughts.
