New wheel: Kosei K4R
Old Dec 20, 2011 | 10:42 PM
hayden's Avatar
Ligher and cheaper than than RPF1s. Oh my.
Kosei K4R Light Grey Painted
Old Dec 20, 2011 | 11:06 PM
Hootie's Avatar
Really now? How much does the 15 inch weigh?
Old Dec 21, 2011 | 12:10 AM
hayden's Avatar
4-100 15x7 ET 30 (11.5lbs) or ET40 (10.7lbs)
4-100 15x8 ET 35 (12.1lbs) or ET20 (13.1lbs)
4-100 16x6.5 ET45 (12.8lbs) or 16x7 ET43 (13.6lbs)
Wow.
Old Dec 21, 2011 | 01:50 AM
feared's Avatar
rpf1s in 15x7 are still lighter...
+35 (9.9 lbs), +41 (9.5 lbs)
Old Dec 21, 2011 | 02:08 AM
Texas Coyote's Avatar
I recently got a set of the 16X6 1/2"-45mm Kosei wheels ... I like them but the Eagle GT tires I put on them are much too heavy... I like not having the tires sitting close to the wheel well opening.. They don't scream out "Boy Racer" like cars with the flush look and the sides of the car stay cleaner on dirt roads and when it rains.. I have never had as good traction with other tires that I get with the Eagle GTs, but my acceleration and fuel mileage is way off.... I'll get some ultra high performance summer tires for my 15" RPF1s before summer is over if not sooner... The Kosei wheels look great though.
Old Dec 22, 2011 | 10:57 PM
LscAndrew's Avatar
Nice, I'm gonna buy this when summer comes.
Old Dec 22, 2011 | 11:21 PM
DiamondStarMonsters's Avatar
Dunlop Star Specs or Hankook RS3!
Old Dec 23, 2011 | 04:41 AM
Something really sticky and sized at 195 50 15" would be great.. I had 195 45 16"s on my heavier 16"X7" wheels and they were pretty decent except when the temperature was lower than 50F they would spin like crazy... For about 15000 miles the Conti Pro Contacts in 195 55 15" mounted on RPF1s were great but they were getting squirrely. One went flat on the rear at about 80 going down a hill and was ruined. Slightly less diameter = lower final drive ratio so I was thinking that the 205 50 16s would be OK, even though they were heavy... Unfortunately I was very wrong. I was driving in a major downpour on Monday in standing water over an inch deep in places and even when I had the accelerator down at over 5000 RPM and higher in 2nd gear the tires never broke loose... The stock Dunlops would break loose and hydroplane doing that even before boost was installed... It has been a over a year since I have heard or felt the ABS kick in when braking. I had to brake hard enough I thought for it to kick in a couple of times since on the Goodyears but it still hasn't happened and the car just refuses to break loose... When I have to merge with fast moving traffic from a stop the tires do squall a little in 1st and again just a little more than a chirp after topping out 1st and hitting 2nd... I suspect that part of the reason is due to the weight of the tires but how much is hard to tell.. The weight really wouldn't be a bother if it didn't affect how long I have to be over the center line on two lane highways when passing some asshole that is driving 20 under the speed limit while on their cell phone, and 27.7 MPG on the last relatively conservative driven last tank of fuel.. They will do very well for driving on cold wet roads we only have to deal with for a few months a year...+
Old Dec 24, 2011 | 06:12 AM
Zangoose GD3 Blue's Avatar
what about the RE-11 ???
Old Dec 24, 2011 | 12:05 PM
hayden's Avatar
Wow, didn't know those got so light. I was looking at the larger sizes on the Kosei, which tip the scales in their favor a bit (from what I could tell.)
Old Dec 24, 2011 | 12:08 PM
hayden's Avatar
Didn't know you got these! Cool! I know getting pics online is not the easiest thing for you (or so you've mentioned) but I'd love to see what they look like. Not many pics online of them at all.
Old Dec 25, 2011 | 10:47 AM
I'll see if my brother in law can help me with posting pictures.... They fit very much like the stock wheels which to me is a very good thing but I know a lot of people are more into the hella flucked thing.
Old Dec 25, 2011 | 04:20 PM
isis07734's Avatar
Would these in 15" with 195/60 look too small on a GE ya think? Stock suspension.
Old Dec 25, 2011 | 04:28 PM
doctordoom's Avatar
Supervillain
In my opinion, yes. I think the GE Fits should have at least 16" wheels or it looks too small in the wheel well.
But I would change my opinion in a second if I see one that looks right.
Old Sep 18, 2012 | 12:02 PM
isis07734's Avatar
With the 16x6.5s, do you guys think i'd have a hard time with certain 205 tires?
Thanks
Old Sep 18, 2012 | 12:52 PM
Thanks
I have K4Rs with 205-50-16s and all is well...
Old Sep 18, 2012 | 01:09 PM
isis07734's Avatar
Cool,
it doesn't bulge too much? Taken hard turns in it?
Is there any reason why one would want to go with a x7 vs a x6.5? Am I just being paranoid?
I am looking at buying from TireRack, when the car is brought to Honda to reprogram the TPMS sensors, do they have to take the wheels off? or just plug in the computer?
You bought the sensors with the wheels or transferred from orig wheels?
Thanks, T. Coyote
Old Sep 18, 2012 | 01:36 PM
Wanderer.'s Avatar
I've also pretty much decided on these wheels in the 16x6.5 variety for weight and cost reasons, so i'm interested in pics as well TIA
Old Sep 18, 2012 | 02:03 PM
Hootie's Avatar
Cool,
Thanks, T. Coyote
The TPMS system doesn't have to be reprogrammed during sensor transferal SO LONG as a sensor isn't damaged or broken in the transfer process OR if a NEW sensor is being introduced to the system.
Whoever is transferring the sensor will just need to carefully break the outer bead of the tire (or dismount tire completely), remove the cap with a 11mm 6-point deep socket and transfer the TPMS sensor's cap, nylon washer, and the sensor itself over to the new wheel; making sure that the hard rubber that seals the valve steam around the wheel and sensor is not damaged (which is rare unless dry rotted).
What year or generation is your Fit? 205/45R16s are recommended for the GD chassis and 205/50R16s are recommended for the GE.
Old Sep 18, 2012 | 02:23 PM
isis07734's Avatar
Thanks, Hootie!
Good info!
Just got back from my 1st free oil change at honda, asked the guy there about TPMS with non honda wheels, he said it would be a crap shot.. so i'm not sure i'd trust they wouldnt break em.
Pretty sure TireRacks TPMS installed have been working fine with the Fit's reprograming from what i've read.
I have the 2nd gen/GE/2012 btw.
