so I trieds to install speakers and hu and failed this is imposible
Old Feb 16, 2012 | 06:11 PM
mdsniper7's Avatar
the door panels have 3 clips and they won't come out I pull em push them forawd and nothing.
Next the headunit tells me to remove 3 ac cables wtf what cables.
next sub where is are firewall hole can't find it so wtf do we have the drill.
this car is a pain
Old Feb 16, 2012 | 06:36 PM
lashlee's Avatar
I would take it to a specialty shop and have it done correctly. The parts to replace what you break will be more expensive than the money to have it done by a pro. If you have to do it yourself I would look at some of the installs on here. I'm pretty sure there are a few DIY's on here.
If you are determined to do it yourself, the doors should pull off after you've pulled the three screws and the cup behind the interior door handle. The HVAC has three cables that run to the vent selector, the recirc control the heat/cold selector. They pull out after you unclip them. As for the power wire, I had an auto so I drilled a hole in the plate that is there for the clutch pedal assembly.
If the Fit is a pain, you've never worked on a BMW, Benz, Porsche, etc...
Old Feb 16, 2012 | 07:53 PM
mdsniper7's Avatar
I have only instaled on american cars berfore, but i wont pay someone too, its either better sound or I sell this evil little car. I need something, the biggest issue is the door panel armrest area I dont know how to get those off, do I pull em push up or push in I dont know.
also the three ac control things are the ends a steel ring I need to pull off.
Old Feb 17, 2012 | 05:56 AM
Black3sr's Avatar
Sounds like no patience so sell it.
If you have a GE then go here for door panel removal.
https://www.fitfreak.net/forums/2nd-...ml#post1021459
Old Feb 17, 2012 | 08:06 AM
Goobers's Avatar
Nope he has an 08.
Old Feb 17, 2012 | 09:59 AM
Btrthnezr3's Avatar
I could probably take my door panel off in less than a minute.
Calm down and search for a thread with more details.
I know there is a GD thread for door panel cloth recovering so it should have door panel instructions.
I've also seen various stereo install threads.
Old Feb 17, 2012 | 10:35 AM
Black3sr's Avatar
Calm down she says. Now that is a good one.
Nah trade for a GE. The door panels were upgrade on the GE so we could mess them up more easily.
Old Feb 17, 2012 | 12:56 PM
Btrthnezr3's Avatar
Hardy har har.
Old Feb 17, 2012 | 03:43 PM
Fit4Spl's Avatar
I can tell you this, if you have NO patience don't bother you will likely break something either the car, or the audio gear and then you are out money. It would be better to pay someone to put them in than damage the gear or your car in the process. When I did my car, I didn't even research how to remove anything, but with my experience in doing car audio it was a bit easier for me to figure out. But someone with no experience as I said will break something or just get frustrated and quit. No need to get frustrated either do the leg work in research or find someone to install it for you.
Hell, you are in Tampa, I am in Orlando if you wanna do the drive I can do the install for you and I will give you an amazing price, you can PM me if you are interested in that option.
Old Feb 17, 2012 | 06:46 PM
mdsniper7's Avatar
well finally got to the head unit lol but the door panels just make no sense its really confusing
Old Feb 18, 2012 | 01:25 AM
hiwatt357's Avatar
Old Feb 18, 2012 | 02:02 PM
mdsniper7's Avatar
i googled that and went to every forum possible but noone says how they got those 3 clips out I have been trying to figure them out.
Old Feb 18, 2012 | 05:46 PM
lashlee's Avatar
Are you talking about the three under the armrest? I used to flex it slightly and use a flathead or a panel tool to release the clip and pull it from front to back. At the rear of the armrest (or the side farthest from the door hinge) is a tab. The clips at front must be removed first then pivot it towards the interior of the car so you don't break the tab.
Old Feb 18, 2012 | 05:47 PM
Sooner97's Avatar
You need to use some plastic fastener removers. Use one to gently pry the trim up and look for the plastic clip that connects it to the door. Slide the remover under the the clip and lift it up and it'll pop right off. I bought these and they work great:
Amazon.com: Astro Pneumatic 4505 5-Piece Fastener and Molding Remover Set: Home Improvement
FITment
Dec 28, 2010 10:11 AM
jcschlic
Apr 30, 2010 03:40 AM
drock305
Apr 10, 2010 10:43 PM
micchung
Mar 29, 2008 07:12 PM
FitLIKEaGlove
Nov 12, 2006 08:42 AM
