Help with different sound deadening products
Old Feb 19, 2012 | 03:07 PM
FELIXY69's Avatar
I think I m done with modding the fit after doing this.....
I need to cover my entire car in sound deadening products
There are so many brands out there and they all claimed to be better ...!!!
From ur experience of comparing .... Which is better???
I need to get rid of heat transfer from engine and vibration cuz I m running ultra stiff engine mounts ..!
There are few products out that I m looking at including
Dynamat
Fat mat
Brown bread
What to use ?
Old Feb 19, 2012 | 07:40 PM
Fit4Spl's Avatar
SecondSkin, if you want more information I can get you a contact for them. I have my fit done in it, almost 100% coverage and I love the stuff.
Old Feb 19, 2012 | 10:10 PM
lashlee's Avatar
I've never used SS but I've competed against guys that have used it in the past, and will probably use it for my next big install. I've used Raammat in the last three big installs and have been very happy with the results. In two of the installs I went as far as covering the roof skin and you can notice it in the rain, especially. As long as you keep with a reputable brand you should do well. I've seen it where cheaper brands get brittle after the application and may peel up after some time. In the past I've used Dynamat (both regular and xtreme) Stinger, PG, RF, Cascade as well as some no name stuff. Usually better stuff is easier to apply and don't ooze out of the edges.
Old Feb 20, 2012 | 05:20 PM
FELIXY69's Avatar
I want to know what I should use to stop the heat coming in from my engine bay ??
Is SS GOOD FOR COVERING THE BOTTOM of the dash ?
Old Feb 20, 2012 | 06:31 PM
FELIXY69's Avatar
Let me know if this is over kill .... As in too thick and the OEM carpet will have a hard time going back in ....
I m planning to use dynomat extreme as a base layer on the entire car
And then use dynaliner on the entire cAr
And onto of that I want to add dynapad on the front half and fire wall area
Inside the engine bay I m going to put dynashield on the fire wall......
Will this be too much ??
Anyone have experience with these products ?
Old Feb 20, 2012 | 06:46 PM
Fit4Spl's Avatar
It's not too much unless you are referring to cost, dynamat is over priced period. SecondSkin has everything you could need and their prices are great.
Contact Jon at secondskinrepjon@gmail.com tell him ALL4SPL sent you, that is what the audio world knows me as. He will answer any questions you might have as well as be able to give you quotes on products.
Old Feb 20, 2012 | 08:21 PM
FELIXY69's Avatar
Thx i will contact him asap ...!
alvinchua
Mar 1, 2014 02:12 AM
13fit
Jan 13, 2013 10:28 AM
TFREEfit
Jan 12, 2011 07:35 AM
thefit09
Aug 26, 2009 02:56 AM
blackvitzrs
May 4, 2009 06:20 AM
