Tire Pressure help?
Old Mar 25, 2012 | 10:57 PM
Starscream's Avatar
Tire Pressure help?
I have a 2012 fit sport not and i am not sure what the tire pressure should be for the car? The wheels say max 51 but the door jam says 33 ? any idea?
Old Mar 26, 2012 | 01:53 PM
use 33psi when cold (morning before you drive your car). if you're going to pump air at a gas station, use 35psi since the tire's warmed up.
DONT pressure up 51 as it can burst upon impact with a pot hole or a manhole lid.
your spare tire in the trunk should be pressured up to 60psi, but with summer temps coming, keep it around 58psi.
Old Mar 26, 2012 | 05:16 PM
Brain Champagne's Avatar
As the manual says, the tire pressure for the car is posted on the car and in the manual. What's on the tire is the max pressure ever for any car with that tire, and it's got nothing to do with what you are supposed to do with your Fit.
(now I'm sure random people will post a bunch of reasons why they disagree with Honda; for tire pressure I stick with what the car co says, because they're engineers and have actually tested stuff scientifically)
Old Mar 26, 2012 | 08:27 PM
mkane's Avatar
Running 33 at the moment. Tried 30 as the roads here are pitiful, but handling is compromised if you ramp it up.
Old Mar 26, 2012 | 10:14 PM
Goobers's Avatar
a warmed up tire can go up by 6 degrees.
japspeed
Apr 11, 2014 09:29 AM
Starscream
Feb 14, 2013 05:14 PM
boots11234
Oct 27, 2008 03:55 PM
RichXKU
Sep 29, 2008 07:26 AM
