Possible to make power outlet non-switched?
Old Jul 21, 2006 | 01:43 PM
Balorn's Avatar
One of my few complaints about my new Fit is that the power outlet (aka "cigarette lighter outlet", for us old-timers ) is switched, meaning that it's only on when the car is on.
Is it possible to make it stay on all the time, so I can leave something plugged in to charge overnight?
If I have to take my phone or MP3 player inside to charge it overnight, sometimes I forget to take it back out to the car when I get ready to leave for work.
In every car I've used it in before (admittedly limited to a Neon and a PT Cruiser), it was on all the time, so I got used to that.
Old Jul 21, 2006 | 02:30 PM
sam's Avatar
sam
Lightbulb General electronics answer
You can certainly power it from a location which is not controlled by the ignition position. I'm sure someone will tell you which fuse etc. Presumably someone has done this but I've not seen it discussed here.
so... yes
An easy way to find a fuse is to use a simple 12v tester and see which are live. The fuse cover tells you about the fuses that are already in use- along with a few that are used for options. Presumably the empty slots (not the storage slots) are available for use.
You can also always draw power from battery and bring it in. Be sure to place a fuse inline.
Again, hopefully someone did this already and can hand you a pre-packaged answer from experience doing exactly this. Also should be an easy and relatively inexpensive mod for a competent mechanic to do for you.
I don't know if anyone has a NA Fit wiring manual- it is always mentioned along with this kind of thread but nobody seems to have it yet.
Bet wishes-
Old Jul 21, 2006 | 02:34 PM
sLiVeRwOrM's Avatar
Four Wheels Enthusiast
somepeople like that becuase its an easy fuse to tap into for powering an amp
Old Jul 21, 2006 | 05:58 PM
willmax11's Avatar
Very interested in the solution to this as every winter I've plugged in a 5W
solar PVC trickle charger in my other cars to keep the battery at it's best in -30.
RavenManiac
Dec 28, 2017 12:58 PM
SilverEX15
Aug 25, 2014 08:29 AM
MookHustle
Aug 23, 2009 07:13 PM
angeldragon0
Mar 4, 2008 04:04 PM
benlinus
Nov 21, 2007 12:36 AM
