sparkplugs???????
Old Jul 23, 2006 | 03:40 AM
GD1TypeR's Avatar
sparkplugs???????
hey everyone,
thanx for da info on the 91 vs 95 octane. well its almost time for my 30000km maintenance and the dealer suggests a sparkplug change. i'm not sure wat type or brand the factory uses but i figure since i have to change then might as well upgrade. can anyone tell me wat type and brand would help my fit run better? my engine isnt modified but i just want to run smoother/better.
thanks
Old Jul 23, 2006 | 04:45 AM
fm2n's Avatar
Originally Posted by GD1TypeR
hey everyone,
thanks
Stick with OEM - NGK
Old Jul 23, 2006 | 07:49 AM
FitInFla's Avatar
The spark plug change at 30K is only for non-platinum plugs. When I got my FIT a month ago I was told that the plugs didn't need to be changed until 100K miles.
Old Jul 23, 2006 | 08:37 AM
rudy's Avatar
Have they told you how much $ they want to change your plugs? I ask because often times dealers charge a lot for this, and it's truely unnecessary to pay a premium to have the dealer do the change. It's extremely easy to do, and worth learning how to examime old plugs, gap new ones, and install/tighten them properly.
Old Mar 12, 2008 | 08:24 PM
jake696's Avatar
That's crap, I have 100,000 miles on our 3 Fits and we are just now considering changing plugs...
Old Apr 9, 2008 | 01:35 PM
MarkB's Avatar
Ha!
Got to love the Dealership stories. What bunch of parasites.
Old Apr 9, 2008 | 01:46 PM
manxman's Avatar
All of the previous posters are RIGHT! For sure, don't let the dealer get their hands on your wallet for such a flimsy excuse.
Old Apr 9, 2008 | 07:34 PM
jake696's Avatar
AND really...
With unleaded gas you can get almost lifetime mileage from plugs. I've taken our Matirx vehicles to 190K before changing plugs. Those vehicles are run at highway speeds, 250-325+ miles every day, on 87 octane fuel. STAY away from 10% ethanol, unless you like putting O2 sensors, catalytic converters and fuel pumps in your vehicles.
Even the oil and lube folks are begging me to put plugs in earlier than that, they are programmed to do it! I show them the detailed mileage and fuel logs we keep on the cars. The gas mileage doesn't drop and they run fine. the Toyota's have an iridium tipped plug that just won't wear out. Not sure about the Honda's but I think they are just platnum?
Old Apr 9, 2008 | 07:37 PM
RoachsRSX-S's Avatar
More than likely iridiums as well.
Old Apr 9, 2008 | 11:51 PM
jake696's Avatar
Not too sure...
As I recall they didn't cost as much to replace as the Trix plugs...I'd have to go pull the bills to check. Someone in here should know, but I don't think they're iridium...either way, no reason to change before 100K...unless...perhaps...that 100K was all city driving, lots of idle?
Even then, I'd sure like to see one first. Problem is, the serivce guys won't pull one just to look, if they (actually YOU pay) invest the labor, they want to replace!
Old Apr 10, 2008 | 12:59 AM
OEM plug is a Laser Iridium
http://www.ngksparkplugs.com/part_fi...uv/results.asp
I may have f'ed this link up ^^^ .. but if you go the NGK site, just input the info.
Old Apr 29, 2008 | 07:46 AM
Yongjin's Avatar
how to know if spark plug got problem or lousier than original
problem goes like this just did 20k servicing and the workshop recommend change spark plug so ok then they change denso iriuium plugs... all 8 of them....
bt after the servicing i find tat i need to floor more to get respond... although my rpm go up fast.... (bt this possibility cos i change to light weight crank pully few wks before i did the servinging) and my millage drop frm 14-15 km/l to abt 13 km/l
should i go to honda parts shops n get a set of 8 original oem sparks n ask them change or i should keep the denso iriuium plugs
Old Apr 29, 2008 | 07:58 AM
jake696's Avatar
all 8?
8 plugs? WTF? You got bigger problems than a pulley!
Old Apr 29, 2008 | 08:02 AM
Yongjin's Avatar
huhz???? my is a 1.3A iDSI engine it has 8 spark...
Old Apr 29, 2008 | 08:31 AM
GD1- your dealer sounds like my local rip-off subaru dealer.
Old Apr 29, 2008 | 08:41 AM
Yongjin's Avatar
..............its the spark problem ????? ignore the pully tat was done at at reputable shop n dyno test tat 1 was done before my servinig n was gd till i went to the servicing...
Old Apr 29, 2008 | 08:43 AM
apparently he got a new phone.
Old Apr 29, 2008 | 08:51 AM
Yongjin's Avatar
nvm i dought i going to get any help frm here.... pay another hundred bucks get my performance workshop to do a chk is faster
Old Apr 29, 2008 | 10:03 AM
Yongjin- im just kidding. carry on.
uniguar
22
Jul 1, 2014 06:42 PM
CrystalFiveMT
Aug 2, 2013 09:28 AM
kirinzon
May 10, 2011 08:46 PM
get_FIT
Nov 20, 2010 11:01 AM
Papparock
Nov 16, 2009 02:23 PM
