Rubbing................
Old Jun 22, 2012 | 01:52 AM
Nicotine's Avatar
So, i ordered a set of enkei ev5 in bronze. the wrong offset was ordered initially (+38). i sent them back and re-ordered +45 (17x7).
im still getting crazy rub of my front fender liners during faster turns (not fast, but even fairly slow paced they rub) and over any moderate bumps.
1.6" tein springs (same as i have on my Si, no issues, 45 offset 17s).
is it possible that tire rack sent me another set of 38 offset rims? how can i check?!
is there anything i can do, other than use different springs? (1 inch drop instead of 1.6?)
thanks guys.
Old Jun 22, 2012 | 01:57 AM
ThEvil0nE's Avatar
rubbing on fender liners has nothing to do with offset... you might already be bottoming... check your struts
Old Jun 22, 2012 | 01:58 AM
Nicotine's Avatar
i looked, still has shaft distance.
i can see and feel the damage being done to the liner already.
Old Jun 22, 2012 | 02:06 AM
ThEvil0nE's Avatar
Old Jun 22, 2012 | 02:17 AM
Nicotine's Avatar
i just lowered the car tonight...... before lowering, no rubbing. lower 1.6", instant rubbing.
the car is low km, the struts with stock springs were fantastic: it rides great.
will going to a 1" spring fix it?
i get what you're saying: but if i do the struts and it STILL does it due to rim offset or spring height: then i should fix one of those also.....?
no point buying struts if they arn't blown....
Old Jun 22, 2012 | 03:04 AM
krunk13's Avatar
Install camber kit
Old Jun 22, 2012 | 03:27 AM
MNfit's Avatar
What size tires you got on there?
Old Jun 22, 2012 | 04:05 AM
joey_fits's Avatar
The offset should be stamped on the back of rim. Did you have an alignment done? If not talk to the tech about camber bolts. Also bending up the tabs that hold the liner can buy a little room as it'll push the liner up. Hope that helps some
Old Jun 22, 2012 | 04:12 AM
krunk13's Avatar
are they used springs?cause teins sag like old lady boobs
Old Jun 22, 2012 | 09:57 AM
apexanimal's Avatar
this
and look on the back of the wheels... they should be stamped with size and offset info...
Old Jun 22, 2012 | 10:03 AM
Nicotine's Avatar
gonna look at the offset size and tire size when i get the car back from being tinted this aft.
if i bend the tab upwards as suggested, isnt the plastic bumper also bolted to that part?
i'll have to take a look. i really love how it looks, but even the smallest bumps make me cringe.
as for camber...... i really don't wanna go that route. this is my daily/winter beater. i was hoping to keep this simple, but i guess not.
Old Jun 22, 2012 | 10:27 AM
krunk13's Avatar
Camber is easy and the bolts cost $26. Just take it to get an alignment and ask the tech to install the bolts and add some camber
Old Jun 22, 2012 | 11:35 AM
DreaMv's Avatar
just get the fenders rolled... easy fix lol
Old Jun 22, 2012 | 12:15 PM
JDMchris.com's Avatar
I run THIS
OEM shocks suck. that is why you are rubbing while you are lowered. The body lean created is what makes it rub... not the tire size/offset. If you had stockers it would rub too.
Old Jun 22, 2012 | 01:45 PM
Nicotine's Avatar
i'm not concerned about camber, etc. been there, done that. :P
what shocks would you guys recommend for the fit?
Old Jun 22, 2012 | 03:49 PM
ThEvil0nE's Avatar
none really out there. what are you dropped on? I'm on swift springs with 17 wheels and have not had any issues with fender liner rubbing even with heavy loads. I also drive pretty aggressively specially on turns/ramps.
Old Jun 22, 2012 | 05:03 PM
joey_fits's Avatar
I thought this was solved in the will I rub thread?? Which I believe the answer was yes you will. Save up for coilovers..or become concearned with camber
Old Jun 22, 2012 | 05:56 PM
ThEvil0nE's Avatar
camber has nothing to do with it.
@op: sorry, I missed it... you have tein springs... they are kinda soft
Old Jun 22, 2012 | 06:08 PM
krunk13's Avatar
Ohhh....so thats why you see so many Tein springs for sale
SHOELAC3D
Aug 27, 2014 02:57 PM
gsx-r35
Jun 9, 2011 01:42 PM
Happy__Fit
Jun 16, 2010 01:19 AM
SikxChoi
Jan 13, 2010 02:51 AM
Reinert79
Mar 22, 2008 05:14 AM
