Which circuits are tied to "position one" on the ignition (like the radio)
Have added an extra cigarette lighter accessory outlet(s) using an add-a-fuse. All fine and good but they only go hot on position 2 (run) on the ignition based on the circuit I've tapped (lock/radio, 10 amp). The radio itself runs when the ignition is in position 1 or 2. Are there any circuits (ideally fused 10A or less, the add-a-fuse max is 10A) that are tied to position 1? Based on my scan of the list of circuits at the fusebox in the owner's manual I'm thinking no but maybe somebody knows.
This is admittedly a total nit, but if there's ever a time when I want to run the radio at position 1 it's likely I'd want to use accessories too (like a cell phone charger or ipod or satellite radio...).
Thx
Thx
I would have thought that the key lock/radio (fuse 14) would have been hot in position one. A quick scan of the fuses suggest the following:
Fuse 61 (radio)
fuse 24 (stop / horn ) - this is hot all the time
fuse 29 (small light) - this should be hot all the time
Fuse 61 (radio)
STOCKTREK
Jul 25, 2011 06:09 AM
