Wheel Size Question
Old Aug 24, 2012 | 08:04 PM
fittmann's Avatar
Wheel Size Question
Can anyone tell me if it would be feasible to use 2011 Insight 15" wheels, w/ 45 mm offset on my 2012 Fit Sport? I'm planning on using a 195 or 205/55 R15 size tire to minimize speedometer issues. I know I'll have to have TPMS sensors. Thanks in advance for any/all assistance!
Old Aug 24, 2012 | 11:01 PM
mahout's Avatar
Far as I remember the Insight wheels are 4 bolt, 100 mm bolt circle and work fine at 45 mm offset but confirm, especiaslly for clearance around calipers. If its close you can add 1./4" spacers to clear the caliper. RThey are lightweight and the tires are fine.
BTW, cover the dash wearning with black tape; TPMS is merekly government nanny goat. Check your tire pressures regularly and spending $100 for sensors is unnecessary.
Old Aug 24, 2012 | 11:06 PM
mkane's Avatar
If there 4x100 don't see why not. ^^^^^^^Beat me tuitt
Old Aug 25, 2012 | 07:56 AM
specboy's Avatar
Running Black Tape on a '12 will have an impact on the VSA also so it's not just a dash light. (should be in the manual)
~SB
Old Aug 25, 2012 | 08:27 AM
mahout's Avatar
~SB
The guy autocrossing his '12 on aftermarket wheels doesn't seem to have a problem. And if taping the dash warning turns VSA off you can bet there'll be a ton of tape applied.
Perhaps thats why its not in the manual.
ellatron
Oct 29, 2014 07:00 PM
littleblackcar
Oct 18, 2013 04:35 AM
djk949
Jan 7, 2009 08:32 PM
GD3_Wagoon
Jun 26, 2008 08:01 AM
DrDiff
Mar 21, 2007 11:18 AM
