GE Wheel size?
Old Oct 17, 2013 | 12:35 AM
littleblackcar's Avatar
GE Wheel size?
Can anyone tell me the exact size, offset, and bore of the 2011 Base wheel? Thanks!
Old Oct 17, 2013 | 11:01 AM
mahout's Avatar
Its a 4x100 bolt circle, meaning 4 bolts 90 degrees apart on a 100mm diameter circle thru the center of all 4 bolt holes.. The hub is 58 mm but if its a problem you can use quarter-inch spacers to clear the wheel from the hub. The wheel is held by the bolts and not the hub center no matter what others say. Its just an aid to instaklling. The wheel nuts are 12x1.5 mm and be sure the nuts have the same seat as the wheels. Unfortunately there are 3 different angles involved. Getting wheels that use the OEM nuts is good.
Standard offset is 53 mm but you can easily drop to 45 mm, or even 40mm if you are careful to not go more than 195/40 on 17" wheels.
The fact that its a 15" steel wheel is not that important. They're only good for snow tires.
Old Oct 17, 2013 | 11:12 AM
Wanderer.'s Avatar
Size: 15 x 5.5J
Offset: +55
PCD: 4x100
Bore: 56.1
Why is this in the GD section?
Old Oct 17, 2013 | 02:58 PM
Thanks for the info!!
Old Oct 18, 2013 | 04:35 AM
Black3sr's Avatar
Size: 15 x 5.5J
Offset: +55
PCD: 4x100
Bore: 56.1
Wandered into the wrong section?
HermTDI
Mar 12, 2015 03:53 AM
djk949
Jan 7, 2009 08:32 PM
Korywithak
Nov 25, 2008 12:58 AM
jazzista
May 22, 2008 08:25 PM
ew_deathscythe
Mar 21, 2006 09:49 PM
