Skunk2 Short Shifter $15
Old Nov 1, 2012 | 05:46 PM
JDMchris.com's Avatar
I run THIS
Skunk2 wanted to do a sale for you guys on their overstock of short shifters for the GD3. For $15 why not?
No code, no group buy necessary. Simply go to:
628-05-0200 - Short Shifters - Accessories - Skunk2 Store
and order
Old Nov 2, 2012 | 08:13 AM
martymcfly's Avatar
Thanks for the heads up. I will get one for my GD1
Old Nov 5, 2012 | 03:02 PM
Fit4Trav's Avatar
very nice deal!
Old Nov 5, 2012 | 04:45 PM
TPColgett's Avatar
I have/have tried every other short shifter offering... might as well see if this does anything : /
Old Nov 5, 2012 | 05:34 PM
I run THIS
you can always add this to your existing short shifter, make it a super short shifter! lol
Old Nov 5, 2012 | 06:40 PM
TPColgett's Avatar
I'll add this to my Mugen shift box, H-Fit hard mounts and solid derlin under hood shift bushings.... I still doubt that will eliminate my issue though I have so much side to side slop in gear, other drivers think it is still in neutral and stall it.
Old Nov 6, 2012 | 04:32 AM
dj_konix's Avatar
i'd be keen but they only post expedited and that adds $90 to the cost FML
Old Nov 11, 2012 | 06:28 PM
BlueIntegraBoy's Avatar
Thanks for the heads up. Ordered.
I ordered an extra. I would be able to post it for you when I get it. $20 (my cost with tax, and some gas to the post office) + $37 USPS priority mail to you. I won't be able to send out until Saturday as it is my only day off.
I just installed the SS adapter today. Like everyone says the white cap at the end of the stock shifter is a bitch to get off. After trying different methods outlined in the Skunk2 SS thread, I found the easiest way to remove it was to get a small vice grip to pry and use as leverage. Most difficult thing about the install was trying to tighten the three allen screws. It is at such a bad angle. I haven't taken the car for a spin yet, but just going through the gears it's a slight improvement.
Old Jun 6, 2013 | 05:44 PM
Juan2Six's Avatar
These are still available from Skunk2.. for $15 why not indeed.
I ordered a set.. even if the shipping up to Vancouver (~$20.) costs more than the parts.
Old Jun 6, 2013 | 05:46 PM
TPColgett's Avatar
I actually managed to add this to my setup... Had to notch the tunnel for the shifter to clear though
Made a VERY noticeable difference! Quite happy with the $20 spent!!!
Old Jun 13, 2013 | 09:05 AM
cmt3's Avatar
Wanted to check this fits the uk gd jazz sport model?
I emailed skunk2 before I found this thread and they said it wouldn't fit, so want to double check.
Thanks.
Old Jun 13, 2013 | 09:22 AM
martymcfly's Avatar
Thanks.
I installed this on my GD1 2007 Fit (Brazil) and it fits. I also had the Mugen shifter on my 2007 GD3. As far as I know, both OEM shifters have the same dimension (but the materials are slight different).
The strutking metal washer (designed for GD3) also fits too. I am using that with the skunk2 adapter. It works fine without any problems.
I would suggest to take the cotter pin out and completely detach the shifter (from the cable) during installation. It is much easier to install the adapter that way. I simply don't know how people can "slap" the adapter in place and tighten the 3 allen screws without taking the shifter out
Hope this helps.
Old Jun 13, 2013 | 10:47 AM
cmt3's Avatar
Thanks martymcfly, just ordered a set.
btw they have a new eu site.
http://eustore.skunk2.com/short-shifter-810.html
If you add LAUNCH10 at checkout you will get %10 off your order til the 17th, according to the FB page.
Hope this helps someone.
Old Jun 13, 2013 | 11:03 AM
0bLiViOuS's Avatar
Yep this was the best $20 I spent. I still am getting used to the new throw but the feel is so much better and removed tons of slop.
Old Jun 13, 2013 | 03:10 PM
martymcfly's Avatar
Spend another $30? on strutking metal bushing. You will feel like the shifter is wielded to the chassis
Old Jun 13, 2013 | 03:45 PM
m4sterch3f's Avatar
as soon as i get my alternator working i will hop on this like a lion!
Old Jun 13, 2013 | 06:15 PM
FIT4thetouge's Avatar
Anyone know if these fit the GE as well?
Old Jun 13, 2013 | 07:35 PM
Katsumoto's Avatar
I installed this last night on my GD3.
Hardest part was that damn bushing on the pivot ball. Used a 17mm socket to get leverage and pop it off. Took me about 20 minutes to do it.
Old Jun 27, 2013 | 02:22 PM
GD3_Wagoon's Avatar
just ordered a set for myself: $25.14 shipped to my door. can't wait to install it
Old Jul 29, 2013 | 08:48 AM
puma1824's Avatar
Is this deal still available ?
