Whistling Sound in My Fit
Old Nov 25, 2012 | 09:46 PM
arealitystudios's Avatar
Hello All
First time poster here. I own a 2010 Honda Fit that I have been very happy with. Just today though my engine started making a strange noise.
It is a kind of a high pitched whistling sound, sort of like air escaping, coming from the left side of the engine (if I am standing in front of the car with the hood up). The sound is there when the car is idling and it gets louder and more intense when I hit the gas. It's incredibly loud. It's really hard to tell where the noise is coming from exactly but it is certainly on the left side of the engine.
I looked at the hoses in the area and they all seem solid. The car only has about 20,000 miles on it. The belt around the alternator seems solid too just from a visual inspection.
Dirty valves maybe?
I think I'm going to take it into the dealership but before I do I'd like to get some opinions on what you all think it might be.
Old Nov 26, 2012 | 06:31 AM
StinklePink's Avatar
Usually a vacuum hose that has come loose, no?
Old Nov 26, 2012 | 12:50 PM
mahout's Avatar
Yeah, or a intake hose so check all hoses, big or little connecting to the engine. And don't assume its a loose fitting, many leaks are cracks in the hose itself so feeling along the hose to see if the sound changes is necessary.
Old Nov 26, 2012 | 04:41 PM
Type 100's Avatar
This tells me there's something wrong with the belt. My guess is it's probably gone a bit slack. In that case you can add tension to it by adjusting bolts on the alternator.
If it's not the belt, my guess is an idler pulley bearing gone bad. I'm not sure how the drive belt is wound in GEs, but on GDs there's an idler pulley hanging off the side of the engine block that adds tension to the belt.
Both have happened to me fairly recently but are easy fixes.
Old Nov 26, 2012 | 04:49 PM
Wafulz's Avatar
hmm i think mines might be doing that mines wines too lol 2012 fit
blazej
Feb 24, 2016 07:37 PM
ftlmatt
Jan 9, 2016 02:18 AM
nodelock
Oct 25, 2012 05:43 AM
tigerseye1108
Feb 8, 2010 08:14 PM
KentuckyFit
Jun 18, 2007 09:54 PM
