A hissing sound when turning the car off
Old Apr 8, 2010 | 12:30 PM
ftlmatt's Avatar
i have a 2008 Honda Fit Sport A/T with 21,000 miles on it..
i have noticed that sometimes after i turn the car off, open the hood, i hear a slight hissing noise coming from the left side of the engine, not too far down in the engine.
i have a friend who knows a lot about Honda's and he said it is nothing to worry about...
what do you guys think?
Old Apr 8, 2010 | 04:30 PM
spreadhead's Avatar
If you were using the A/C (or defrost), you are hearing the refrigeration system equalize. This is normal.
Old Apr 8, 2010 | 06:42 PM
Koi's Avatar
Koi
I've had this sound since I got the car, regardless of A/C being used or not.
Old Apr 9, 2010 | 01:56 PM
ftlmatt's Avatar
yeah i only hear it when i do run the A/C...thanks
just wanted to make sure it wasn't a vacuum hose or a leak somewhere
Old Apr 12, 2010 | 03:50 PM
S14b's Avatar
I think it is an angry cat in or around your car. INspect for angry cats.
Old Apr 12, 2010 | 09:51 PM
cr4zy3lgato's Avatar
I noticed that too on mine, but i'm pretty sure it's normal, IMO it's only the coolant from the rad...
Old Apr 12, 2010 | 10:13 PM
HONDAMATIC's Avatar
maybe its from the intake, when you add an aftermarket one its more noticable
Old Apr 13, 2010 | 08:33 AM
It cannot be coming from the intake as the engine is turned off at that time, it sounds like a liquid draining from something... thats why i'm thinking about the rad... it cannot be oil as it seems to be more liquid... the more i think about it, the more i think that it has to be the coolant, it's probably just going back to the reservoir... ftlmatt if it's really such a big concern for you, you should check your coolant tank before and after... you can also check your other fluid levels to be sure it's not a leak. IMO there's nothing to be concerned about...
Old Apr 18, 2010 | 08:35 PM
cessna's Avatar
Its the emissions air pump that you are hearing when you turn the engine off.
Old Apr 18, 2010 | 11:19 PM
spreadhead's Avatar
'07-'08 USDM Fits don't have emissions air pumps.
Old Apr 19, 2010 | 12:06 AM
gimme's Avatar
Master FitFreaker
fuel pump...
Old Apr 19, 2010 | 10:32 AM
CuTeBoi's Avatar
Originally Posted by gimme
fuel pump...
That one is more of a whirring sound... and comes from behidn the engine not to the left... does it?
But I know the fuel return pump runs, and I know the AC one also runs... if the AC was running when you shut off the engine.
Plus this question was answered already.
Old Apr 28, 2010 | 02:54 PM
Scala's Avatar
Today is one of the first hot days in south Florida. and used the a/c today. and i noticed it also. it dosent do it when i dont use the a/c tho
imo thread should be stickied!
Old Apr 29, 2010 | 06:58 PM
ftlmatt's Avatar
i do check it before and after. in fact i check my oil, transmission fluid, brake fluid and coolant levels every other day...i know i'm crazy right? But i really love my Fit Sport
Old May 17, 2010 | 12:40 AM
zmelli's Avatar
It this the Sound you are talking about? YouTube - Honda Fit-Strange Noise.
The Engine was off during the recording of this Video.
Old May 19, 2010 | 12:23 PM
ftlmatt's Avatar
i can't tell!! so many other noises going on...it has been doing that since i bought the car in March of 2008 and it now has over 22,200 miles on it and i have not had one single problem (except for the Aux. Jack..it stopped working,) and one of the mechanics at the dealership said that someone spilled something sticky down in the Aux. Jack.
i told him that is impossible because i don't let anyone else drive my Fit and that open containers are not allowed..only bottles with a screw on cap.
he ordered the part and 30 minutes later it was fixed...i now close the opening whenever i am not using it.
Old May 19, 2010 | 03:18 PM
thefit09's Avatar
One day I had a hissing noise when I got out of my car. It was coming from the tire which had a piece of metal sticking out of it. :/
Old Jun 2, 2010 | 01:15 PM
zmelli's Avatar
This sound is normal, just the AC Pressure relief valve thingy going on.
Old Jun 2, 2010 | 07:05 PM
ftlmatt's Avatar
ok good...not gonna worry about that anymore then.
i live in Fort Lauderdale and my A/C is used almost ALL the time...how often should i get the A/C system checked?
Old Jun 2, 2010 | 07:13 PM
zmelli's Avatar
As long as you do not get any warning lights(red dot on AC Switch on older Hondas) and it is blowing cold, system is good to go. usually it is the Compressor clutch, or clutch swith or relay that goes. I had a clutch go before and what a mess! Fire burning under the hood. the drive belt melted
