08 honda fit sport transmission issues
Old Dec 10, 2012 | 01:16 PM
cheanko's Avatar
hi i have been to a bunch of threads but this thing hasnt been talked about so i am opening this thread.have googled but nothing came up for honda fits buthave a similar problem with a different car.
"ok car is a 95 integra LS automatic. When I'm at a stop light, with my foot on the brakes, the car jerks as if I'm giving it gas, then lets off. Has this happened to anybody? It does this too when I'm driving at low rpms. I am clueless as to what this could be...electrical, tranny, etc. I have no check engine light either. Any help would be deeply appreciated. "
i have the exact problem as this guy and im not too sure if its normal for a fit.i have 93k miles on my car.would appreciate an answer asap so i can bring my car back to the dealer which i bought 2 weeks ago..thanks!
Old Dec 10, 2012 | 01:40 PM
CTCT's Avatar
Hopefully, you're bringing your car back to the dealer regardless of whether or not anyone else has the same problem.
Old Dec 10, 2012 | 01:58 PM
cheanko's Avatar
i will but i want to find out whats wrong with it first..any ideas?
Old Dec 10, 2012 | 07:23 PM
mahout's Avatar
Vehicle idle circuit needs to be checked as well as air intake system, both air filter and MAF circuit.
Spark plugs and coil packs toio.
Old Dec 10, 2012 | 09:45 PM
cheanko's Avatar
so its not the transmission thats messed up?i think they already changed the air filter the spark plugs since they do tune ups before they sell the car.
Old Dec 10, 2012 | 10:19 PM
cheanko's Avatar
found a thread with the same problem but for GE's but no answer?
https://www.fitfreak.net/forums/2nd-...tml#post925993
https://www.fitfreak.net/forums/2nd-...king-stop.html
so is this just normal?
Old Dec 11, 2012 | 02:59 PM
Doug Just Doug's Avatar
The description is too vague to diagnose via the internet -- could be any number of things from complex and expensive to easy and cheap, or it could be something normal that you're not used to (A/C cycling?). Knowing the car's prior history would be helpful. As a first step, I'd simply take it back and have the dealer look into it.
Old Dec 12, 2012 | 02:34 PM
CTCT's Avatar
Don't mean to be nit-picky: I think idle circuit is embedded in the PCU and not changeable. Air filter, unless it's 100% clogged should have no affect at idle since little air is flowing into the engine anyway.
Lastly, just FYI, Fits have a MAP, manifold pressure sensor, not a MAF, mass airflow sensor. The PCU uses the MAP sensor along with a temperature and engine rpm to determine incoming air density. A MAF uses a MAP, temperature, and measured air flow through the MAF to determine air density. The latter is more accurate but more expensive to put in cars.
Colonel Panik
May 31, 2017 06:53 PM
AwlRdy
Sep 29, 2011 01:30 PM
AfterlifeBrock
Oct 30, 2009 01:20 PM
J2THEJ
Sep 7, 2007 08:40 AM
koyotegambit
May 7, 2007 11:52 AM
