Engine mount part number
Old Jan 7, 2013 | 09:43 PM
casandreas's Avatar
During a collision, the upper right engine mount plate bolt flanges shattered as the engine was pushed back, pivoting on the upper left mount. The right mount is okay, but the aluminum mounting flanges where the two bolts attach to the engine housing sheared-off. That part of the engine looks to be a large molded plate or housing that might be replaceable. Does anybody know of a source for a part number. I may weld it, but I'd like to see the cost of the part first. That part handles a lot of vibration and any welds may fail there. I have been unsuccessful in finding an exploded diagram that shows the right side of the engine.
Thanks in advance. It has been an awesome car whose design saved me from injury during the collision. I want to resurrect it to its former glory.
Old Jan 10, 2013 | 07:40 PM
CTCT's Avatar
The aluminum block is cast. To my knowledge, and it's not always good, you won't be able to weld that piece and get the same structural integrity. The cast metal is porous and causes problems for welding. Even if you could weld and get a "good" weld you still won't have the same internal, orthotropic material behavior through the cross section of the mount. Your better off finding a salvage engine for a few hundred dollars and swapping it out.
Old Jan 11, 2013 | 08:49 AM
x4x5x1x's Avatar
Give me a little more info on the car and I might be able to help. Year, make, model, trans or even just the VIN would help.
CJfit15
Dec 2, 2015 10:17 PM
vikaspadickal
Dec 19, 2012 07:51 AM
CuTeBoi
May 4, 2011 06:57 PM
Wave
24
Apr 28, 2008 01:05 PM
jim beam
May 4, 2005 11:16 AM
