Most Mileage from a tank full
Old Jan 22, 2013 | 07:22 PM
DURABLEOILCOM's Avatar
Arrow Most Mileage from a tank full
What is the most mileage youve got from a tank full?
Old Jan 22, 2013 | 08:26 PM
DrewE's Avatar
According to Fuelly, the farthest I've gone between fill-ups so far is 428 miles (using 9.83 gallons).
Old Jan 23, 2013 | 12:42 PM
craneeye's Avatar
419 miles, took 9.9 gallons
Old Jan 23, 2013 | 02:38 PM
Black3sr's Avatar
492 Usually around 480
Old Jan 23, 2013 | 02:46 PM
Rampo's Avatar
That's better than 46MPG! What's your secret?
Old Jan 23, 2013 | 03:20 PM
Schoat333's Avatar
I have a long drive to work so I fill up at 1/4 just in case I sit in traffic for a few hours.
I usually get 285-300 miles on 3/4 of a tank. It always right around 7.5 gallons to fill.
Old Jan 26, 2013 | 01:01 PM
nmfit2008's Avatar
After 4.5 yrs of driving our Fit...the most we have done on a tank is 390 miles. But we don't like to let the tank get too low. It took 9.0 gal to fill the tank...so 43.33 mpg.
That is slightly above our 4.5 yr average...which is 40.56. We live high in the mountains in NM, and we burn 86 Octane gas all of the time. That is regular gas here in NM.
Old Feb 3, 2013 | 02:48 PM
copmagnet82's Avatar
The most I got was 410 miles per tank, but since usually I drive aggressively I get about 320 miles per tank. I got a 2007 Sport Manual.
Old Feb 3, 2013 | 03:06 PM
Texas Coyote's Avatar
Before I did extensive performance modifications to my car I was able to get 38 mpg, driving on a combination of rural roads, in small towns and at 80+mph on highways... By filling to the top of the filler tube while rocking the car to eliminate air pockets I was able to get over 500 miles from a tank pretty constantly... I can only go about 390 miles doing the same thing now.
Old Feb 3, 2013 | 03:20 PM
Steve244's Avatar
Imperial Gallon is larger, of course.
Seriously, this thread deserves an award for the most inane topic on FF. Coyote's anecdote for rocking the car to eliminate air pockets takes the cake.
In a single thread we have encouragement to compromise the fuel system's seals AND run it out of gas started by the op in a thinly veiled advert for amsoil.
Well done.
Old Feb 3, 2013 | 03:36 PM
SilverBullet's Avatar
Well done.
TC anecdote for rocking the car to eliminate air pockets is true. You are actually settling the fuel from surging back and forth in the tank. When I fill the my truck there is a lot of movement and by waiting you can add more fuel. That makes for a more consistent fill and mpg.
Old Feb 3, 2013 | 04:16 PM
Steve244's Avatar
I don't doubt he rocked his car to top it off. It sounds just like him!
A modern fuel system is sealed to prevent fuel vapor leakage into the atmosphere. Topping off and rocking the car to "eliminate air pockets" removes the air space for fuel expansion. At best you'll waste fuel by leaving it on the ground or allowing it to escape to the atmosphere. At worst you'll damage your car.
Next time you're at the Dr's, Bullet, take your owner's manual for reading material.
Page 199 is a "must read."
Old Feb 3, 2013 | 04:25 PM
Next time your at the Dr's, Bullet, take your owner's manual for reading material.
The fuel system is sealed but that does not stop fuel permeation. The reason they don't recommend topping the fuel is due to fuel expansion which I never had a problem topping off my tank. Its more for clean air that they recommend not topping off but look how crazy our weather is the last 10 years. If it was the problem then we should have normal weather patterns by now.
Old Feb 3, 2013 | 04:38 PM
Steve244's Avatar
well slap me silly. To think we've been wasting our time all these years enforcing air standards. durr.
Old Feb 3, 2013 | 04:43 PM
Get off of it Steve.. I've been doing this for over 6 1/2 years without any problems whatsoever.... Like I have told you before, the only vehicle I've done this with that responded negatively to doing this was a BMW R1100 GS.. It ran a little rich for a few seconds evened out and was fine... I have have 2 GMC trucks and a 2009 Forester that I do the same with and have never had a problem... You are good at finding stuff to substantiate your arguments and demand others to prove you wrong with what you and you alone determine to be valid sources of information, find a post based on a personal experience of someone having their Fit screwed up by filling it all the way to the top... It would be nice if you had information based on experience rather than what someone else has claimed that likely as not is as inexperienced as you... You remind me of people that try to tell an old combat vet how to fight a war and how they are more knowledgeable because they saw a John Wayne movie.
Old Feb 3, 2013 | 05:04 PM
Steve244's Avatar
Filling a car with gas is like combat? Your experience rocking your cars to add more fuel (I done it lots of times and nuttin ever happened!) certainly trumps my reading the manual. I cede the battle.
Old Feb 3, 2013 | 10:31 PM
I'd like very much to stomp a mud hole in your ass for belittling Silver Bullet, DSM and myself by insinuating that what we have experienced is wrong or irrelevant because you read something in the owners manual while at the same time insisting that the manual recommends the use of 87 octane fuel which it doesn't. I will give you credit for being the third most annoying person that has ever posted here.. No I can't rate you that high... You're about the sixth or eighth... You are definitely one of the neediest narcissist I have ever seen anywhere though,even on psych wards I had the keys to and a few where I didn't... I've even known people of your ilk that were fragged but that was long ago. Goodnight, I'm going to take my medication and hit the sack.
Old Feb 4, 2013 | 10:28 AM
Bisquick's Avatar
Since I mainly do short drives, I get about 280-330 from a tank. From a fillup to danger low I once did 410 miles. But I really don't recommend it.
My little mini cooper would do 450 easily, i've have gotten a best of 590, but that was an overfill of 14 gallons and a cruise control of 65mph. Small car, BIG tank.
Old Feb 4, 2013 | 09:10 PM
Steve244's Avatar
The holy trinity of ff seems a bit like the 3 stooges when you put it that way.
Old Feb 4, 2013 | 10:06 PM
Out of every one on this site you should be getting the best mpg. Its a sad case that you don't even know that. I am very familiar with Georgia and with the climate you have and I know how the roads are. If you would have listen and tried it from the beginning you would have been able to disprove it if it was not true and have the numbers to prove it but instead you call people names and provide references that you can buy and even put your name on it because they all say the same thing but with different names. So if were the three stooges then that makes you the idiot.
