camber bolts
Old Mar 21, 2013 | 09:17 AM
onetwothree's Avatar
camber bolts
HAs anyone tried camber bolts in the fronts and rears ??
Old Mar 21, 2013 | 12:10 PM
Wafulz's Avatar
if u got the GE/GD its only for the front the bolts
as for rear no camber adjustments are allowed
only GD ur able to add lil washer to make it camber
Old Mar 24, 2013 | 05:24 PM
Mini_Odyssey's Avatar
i need camber bolts bad, my wheels almost look like positive camber stock lol.
Old Mar 28, 2013 | 02:50 PM
RAIN H8R's Avatar
Cam bolts are made by spc I beleive. just installed some on a 00 eclipse im building. Im not a fan, but they do work...
Old Mar 28, 2013 | 04:46 PM
jmsplitfyre's Avatar
Camber bolts up front, shims for the rear.
Old Apr 2, 2013 | 08:02 AM
Yea realised you can't do it I ge rears, anyone have any pictures available with camber bolts? Want to see since I'm thinking of getting some
Old Apr 2, 2013 | 01:28 PM
TPColgett's Avatar
The GE can get around -1.5 degrees of camber with a single bolt in the lower strut hole up front. With two bolts, top and bottom, more will be possible If your going to get that much alignment done, make sure to have the front toe set to zero.
Its a CHEAP investment that improves looks, handling AND tire wear. If you lower a stock GE AT ALL, you WILL end up with positive camber in the front
Old Apr 2, 2013 | 02:49 PM
my '12 GE sport MT is running spc camber bolts on the front along with swift springs.
Old Apr 2, 2013 | 02:50 PM
huh?
Old Apr 2, 2013 | 03:30 PM
Originally Posted by kenchan
huh?
Lol 2nd lol usually you get negative camber, even then, many Mac pherson designs don't get that much camber with mild drops.
Old Apr 2, 2013 | 03:33 PM
TPColgett's Avatar
Well, I have twice now seen a GE go with a "mild drop" on Swift springs get very slight positive camber before the alignment.
Old Apr 2, 2013 | 03:47 PM
hummm... interesting. my GE's running swifts and did not get positive camber. i had the shop do a pre-measure before the camber rods and it was still -0.6 or -0.5 or something.
anyway, the spc bolts i got them dialed into -1.5
Old Apr 2, 2013 | 03:48 PM
I've seen them with wacky toe out settings after a drop but not particularly positive camber. That's just weird, usually by design cars I've dealt with negative cambers with drop, mine is stock suspension by looking from the front the front looks almost positive camber 0.9 while rear looks like negative 0.8 camber. It just looks odd. Also any reason why the fit corners better going left then right? When I corner hard rights it understeers a bit but zero understeer doing lefts at same speed wtf.
Old Apr 2, 2013 | 03:56 PM
TPColgett's Avatar
Passenger side axle is longer than drivers side, usually harder to get power down on right handers with our open diff
Old Apr 2, 2013 | 03:57 PM
TPColgett's Avatar
it wasn't much, like +0.3... I thought it was weird as well!
-1.5 is where it's at for daily
Old Apr 2, 2013 | 11:30 PM
sr.sedan's Avatar
^ that sound like the alignment machine is out of calibration man
whitefitsport
Oct 2, 2018 10:54 PM
jurassicJAM
Sep 21, 2010 12:35 AM
flushge8
Hawaii Community
41
Feb 17, 2010 01:25 AM
FELIXY69
Jul 21, 2009 10:38 AM
Spooling
Oct 9, 2008 02:23 PM
